Carte 4 axes pour upgrade Micro tour MERCACEL et ou UAP1
  • Auteur de la discussion GGV11
GGV11
Afin de procéder à l'Upgrade de ces 2 petites machines très très sympa , j'ai il y a longtemps , trouver cela sur Le coincoin...
  • Pour la fraiseuse elle est mais non fonctionnelles
  • Pour le Micro tour, dont la connectique vers le PC d'un autre age et introuvable
Mais un déménagement et un peu de temps sur d'autres projets, ne ne m'ont pas permit de retrouver le driver de la carte et sa ref exacte et que dire du manuel... aux abonnés absents...
Il semble qu'elle soit du type :
TB6560 Driver Controller (mais d'une version inconnue)
  • Toshiba TB6560AHQ chip - High power, maximum 3.5A drive current chipset !
  • 1-1/16 microstep setting - Higher accuracy and smoother operation than standard 1, 1/2 step!
  • Adjustable 1.5A-3A drive current settings for each axis - 25%,50%,75%,100% of full current can be set for different stepper motors
    *Attention: This driver is the 1.5A-3A version, it's specially designed for stepper motors with rated current from 1.5A to 3A, it's NOT compatible with stepper motors with rated current below 1.5A or above 3A!
    If the rated current your stepper motors is below 1.5A, you can choose the 0.5A-2.5A version!
    Please let us know which version (1.5A-3A version is default) you need immediately after placing a bid!
  • Overload, over-current and over-temperature safety - Full protection for your computer and peripheral equipment !
  • On board current switching - Power output can be set according to specific user requirement !
  • Full closed-type optical isolation to protect the user's computer and equipment
  • Relay spindle interface - Outputs Max. 36V 7.5A for spindle motors or coolant pump (only one device can be powered by this output!)
  • 4 channel inputs interface- Can be used for XYZ limit and emergency stop !
  • Professional design - Two stage signal processing with super anti-jamming !
  • Bipolar constant current chopper drive with non-resonant region - Controls motors smoothly through range without creep effect !
  • Four control inputs (divided into pairs of knives) - Allows setting of limit and emergency stop !
  • Universal architecture - Supports most parallel software MACH3,KCAM4 etc!
Ainsi qu'un petit module , inconnu aussi, permettant de piloter les broches avec:
Connections:
  • LOAD M-
  • LOAD M+
  • AC/DC IN
  • POWER-IN
  • PWM+
  • PWM-
Pouvez-vous m'aider à y voir clair?
Merci d'avance.
Greg de Nîmes
01power
01power
01power
pro-ms
David80
taratata
taratata
taratata
taratata
taratata
taratata
xavtronic
vibram
Dardar88
Dardar88
Dardar88
Dardar88
Dardar88
