obelix77870
@M250GV X550MM AT USD 920.00
750MM AT USD 970.00
@ SHIPPING FREIGHT NEED USD 120.00/SET TO FRANCE PORT
20090826221059890
Home
About QMT
Products
Links
Contact Us
Locations
5 Building 402,Shi Fan Fu Di Jie Fang Street, Bengbu , Anhui Post Code:233000, China T:0086-552-2819255 F:0086-552-2819012
Products COMBINATION MACHINE >> M250GV/550MM/750MM
SPECIFICATION:
M250GV(VARIBALE SPEED)
Lathes
Distance between centers
550/750mm
21-3/5"/29-1/2"
Swing over bed
250mm
10"
Swing over cross slide
145mm
5-3/4"
Width of bed
135mm
5-1/3"
Taper of spindle bore
MT4
MT4
Spindle bore
26mm
1"
Range of spindle speeds
50-2500rpm(Variable)
Range of longitudinal feed
0.07-0.20mm/r
0.0028-0.0079"/r
Range of inch threads
8-56T.P.I
8-56T.P.I
Range of metric threads
0.4-3.5mm
0.4-3.5mm
Travel of top slide
50mm
2"
Travel of cross slide
115mm
41/2"
Taper of tailstock quill
MT2
MT2
Motor
750W
1HP
Drilling & Milling
MT2
MT2
Spindle stroke
50mm
2"
50-2250rpm
50-2250rpm
Max. distance spindle to table
280mm
11"
Max. distance spindle to column
170mm
6-3/5"
Motor
500W
3/4HP
Packing size
1270/1520 x 670 x930mm
50" x 26" x 37 "
Net weight
180/195kg
396/429lb
2009 © QUALITY MACHINE TOOLS CO., LTD
que penssez-vous de ce combiné et du prix
merci d'avance
obelix77870
750MM AT USD 970.00
20090826221059890
Home
About QMT
Products
Links
Contact Us
Locations
SPECIFICATION:
Lathes
550/750mm
21-3/5"/29-1/2"
Swing over bed
250mm
10"
145mm
5-3/4"
Width of bed
135mm
5-1/3"
MT4
MT4
Spindle bore
26mm
1"
0.07-0.20mm/r
0.0028-0.0079"/r
8-56T.P.I
8-56T.P.I
0.4-3.5mm
0.4-3.5mm
Travel of top slide
50mm
2"
115mm
41/2"
MT2
MT2
Motor
750W
1HP
Drilling & Milling
MT2
MT2
Spindle stroke
50mm
2"
50-2250rpm
50-2250rpm
280mm
11"
170mm
6-3/5"
Motor
500W
3/4HP
Packing size
50" x 26" x 37 "
Net weight
180/195kg
396/429lb
merci d'avance
obelix77870
