/* -*- c++ -*- */
Reprap firmware based on Sprinter and grbl.
Copyright (C) 2011 Camiel Gubbels / Erik van der Zalm
This program is free software: you can redistribute it and/or modify
it under the terms of the GNU General Public License as published by
the Free Software Foundation, either version 3 of the License, or
(at your option) any later version.
This program is distributed in the hope that it will be useful,
but WITHOUT ANY WARRANTY; without even the implied warranty of
MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the
GNU General Public License for more details.
You should have received a copy of the GNU General Public License
along with this program. If not, see <http://www.gnu.org/licenses/>.
This firmware is a mashup between Sprinter and grbl.
https://github.com/kliment/Sprinter)
https://github.com/simen/grbl/tree)
It has preliminary support for Matthew Roberts advance algorithm
http://reprap.org/pipermail/reprap-dev/2011-May/003323.html
/* All the implementation is done in *.cpp files to get better compatibility with avr-gcc without the Arduino IDE */
/* Use this file to help the Arduino IDE find which Arduino libraries are needed and to keep documentation on GCode */
#include "Configuration.h"
#include "pins.h"
#ifdef ULTRA_LCD
#if defined(LCD_I2C_TYPE_PCF8575)
#include <Wire.h>
#include <LiquidCrystal_I2C.h>
#elif defined(LCD_I2C_TYPE_MCP23017) || defined(LCD_I2C_TYPE_MCP23008)
#include <Wire.h>
#include <LiquidTWI2.h>
#elif defined(DOGLCD)
#include <U8glib.h> // library for graphics LCD by Oli Kraus (
https://code.google.com/p/u8glib/)
#else
#include <LiquidCrystal.h> // library for character LCD
#endif
#endif
#if defined(DIGIPOTSS_PIN) && DIGIPOTSS_PIN > -1
#include <SPI.h>
#endif
#if defined(DIGIPOT_I2C)
#include <Wire.h>
#endif
