En cours Problème avec une Mega 2560 pro...
  • Auteur de la discussion gaston83
gaston83
Je ne comprends pas ce qui se passe.... dans mon sketch j'ai bien #include <Keyboard.h> mais ...
speedjf37
A priori (testé avec l'exemple keyboardandmousecontrol) ne fonctionne que pour les cartes adaptés HID usb
Léonardo OK
MEGA 2560 NOK
Keyboard
[USB]
Description
The keyboard functions enable 32u4 or SAMD micro based boards to send keystrokes to an attached computer through their micro’s native USB port.
Note: Not every possible ASCII character, particularly the non-printing ones, can be sent with the Keyboard library.
The library supports the use of modifier keys. Modifier keys change the behavior of another key when pressed simultaneously. See here for additional information on supported keys and their use.
Notes and Warnings
These core libraries allow the 32u4 and SAMD based boards (Leonardo, Esplora, Zero, Due and MKR Family) to appear as a native Mouse and/or Keyboard to a connected computer.
A word of caution on using the Mouse and Keyboard libraries: if the Mouse or Keyboard library is constantly running, it will be difficult to program your board. Functions such as Mouse.move() and Keyboard.print() will move your cursor or send keystrokes to a connected computer and should only be called when you are ready to handle them. It is recommended to use a control system to turn this functionality on, like a physical switch or only responding to specific input you can control. Refer to the Mouse and Keyboard examples for some ways to handle this.
When using the Mouse or Keyboard library, it may be best to test your output first using Serial.print(). This way, you can be sure you know what values are being reported.
Cordialement JF
pinou29
Bonjour.
Peut-être la version de l'Arduino qui ne va pas pour ce programme.
Ça m'est arrivé et en prenant une version plus ancienne, plus de problème.
Peut-être ??
Bonne bricole.
Bernard.
gaston83
merci du retour..
là, je suis dans la moïse... effectivement mon prog fonctionne sur la leonardo mais je n'ai pas assez d' IO. Sur quoi je peux me rabattre ?
pinou29
Re,
Si c'est pas "secret défense", tu peux mettre le programme (sketch), je fais un essai d'ici la fin de la semaine, là j'ai deux jours chargés avec mes 3 petits enfants.
Mais tu auras sûrement trouvé la solution d'ici là.
Bernard.
gaston83
speedjf37
Je suis pratiquement nul sur les possibilités d'un Arduino. Mais j'essais de comprendre.
Donc à partir de la leonardo, est-ce que je peux interfacer un PCF8575 en I2C.
jpbbricole
Bonjour Gaston
Du moment que tu trouves le librairie appropriée, quasiment tout ce qui est estampillé i2C et connectable sur le bus i2C de ton Leonardo sur les pin SCL et SDA et, bien sûre, +5V et GND.
Pour ce qui est de ton éventuelle extension de ports, si ce n'est que des ports en sortie, le PCF8575 peut aller, mais s'il y a des entrées et sorties, le MCP23017 est nettement préférable, après il s'agit d'installer la bonne librairie et ça se "manipule" presque comme un port de l'Arduino.
jpbbricole
speedjf37
speedjf37
Je suis pratiquement nul sur les possibilités d'un Arduino. Mais j'essaie de comprendre.
comme l'a dit @jpbbricole il faut installer la lib concernée.
Avec tu as des exemples , tu t’entraines avec et puis tu intègre ce qui t’intéresse dans ton projet
Edit Sinon tu peux utiliser une matrice multiplexée pour multiplier les entrées ,combien en faut il ?
JF
speedjf37
speedjf37
Oui, il me faut uniquement des ports en sorties donc le MCP23017 serait bon pour moi.
Bon, voilà. J'ai flaché la mega 2560 avec le nouveau bootloader. mais pour le HID, il y en a une palanquée.... lequel dois-je prendre ?
1) as tu une MEGA2560 avec un 16u2 ou 32u4 comme interface USB?
2) As tu compris comment cela fonctionne (moi pas encore ! ) ?
NicoHood / HID
JF
speedjf37
c'est une mega 2560 avec un Atmega 16U-TH mais c'est le seul processeur sur la carte.
il y a forcement un ATMEGA 2560 comme processeur principal qui dialogue avec le suivant.
l' Atmega 16U2 fait la conversion USB serie et le téléchargement.
Donc la question que je me pose :
Avec le nouveau bootloader garde t'on la prog comme avant ?
Que faut il faire pour qu'il émule un clavier ou une souris etc ? (est on limité a ses E/S pour le clavier/souris ?)
Peut on utiliser toutes les E/S dur MEGA2560 pour les transmettre via le 16U2 comme touches clavier ?
Je viens de vérifier mes MEGA2560 clone sont équipées de 16U2 donc je peux tester !
Cordialement JF
speedjf37
Absolument , il y a un Atmega 2560 (16U-TH) ... mais c'est tout ... et la puce CH340G qui elle fait la conversion USB <=> Serial
Ok pas du tout la même carte et c'est foutu il faut un 16U2 a la place du CH340G
le méthode d'installation est ici: (en fr en utilisant le traducteur de Chrome)
JF
gaston83
Hé oui, c'est ce que j'allais te dire... le bootloader rentre dans le 16U
gaston83
Donc, les deux cartes que j'ai acheté ne me servent à rien pour mon projet. Car les deux refusent l'include<keyboard.h>.
La seule qui le prends (à ma connaissance) c'est la leonardo.
Je ferais avec... je vais lui planter en cul deux MCP machin et j'aurais 32 sorties dispo ou alors j'utilise la même carte que tu possèdes.
J'attends ton retour d'expérience ... :smt023
et c'est ça qu'il faut..... certainement
speedjf37
Un peu galère mais ça marche.
Résumé:
Install du package NicoHood/HoodLoader2
Lancer sketch Installation_Sketch.ino
Câblage des ISP + condensateur 100nf min
Re démarrage Carte MEGA
Cli LED OK install OK
Installation cartes via fichier préférences choix URL supplémentaires
Ensuite on peut sélectionner les nouvelles cartes dont la 16U2
Charger exemples et tester les différents claviers
test LED caps/lock OK
test clavier avec input 2 ( sur le 16U2 sur le connecteur ISP) OK
En même temps on peut faire tourner un squetch sur LE MEGA2560
Prochain test
Faire collaborer les deux UC le 16U2 pour l'USB et le mega2560 pour les E/S
Sketch 16U2:
Squetch MEGA2560
Ecriture clavier carte MEGA2560 dans Notepad++
Tout fonctionne , mais pas vraiment simple à installer.
Le clavier est en Us donc pas AZERTY.
Comment transmettre entre les 2 UC les codes spécifiques etc
Cordialement JF
gaston83
merci du retour.
As-tu essayé de compilé mon code ?
gaston83
Ce serait bien de mettre en commentaire avant chaque include la lib utilisée
Effectivement, de ce côté là, je me suis pas emmerdé, j'ai télécharger toutes les lib qui contiennent encoder, keyboard et keypad.. :wink: pour la leonardo.
gaston83
Mcar
albatros_del_sur
albatros_del_sur
enzodesilesbaladar
enzodesilesbaladar
Remss57
BidouilleMeca
BidouilleMeca
pascalp
Tayachi Mohamed Amine
CRA2
CRA2
rebarbe
jf62
mickbzh
mickbzh
