SOUCI INSTALLATION DE EMC2
  • Auteur de la discussion tfa
tfa
Bonsoir à tous ,
J'ai installé UBUNTU 10.4 et EMC2 avec un cd live .
UBUNTU marche très bien mais EMC2 se met en erreure dès son ouverture.
J'essaie de m'en sortir seul ,mais la je l'avoue je suis à la ramasse ,complètement dépassé par le problème , d'autant plus que je ne connaissait pas vraiment LINUX avant.
_ voici le copier / coller de mon problème:
Print file information:
RUN_IN_PLACE=no
EMC2_DIR=
EMC2_BIN_DIR=/usr/bin
EMC2_TCL_DIR=/usr/share/emc/tcl
EMC2_SCRIPT_DIR=
EMC2_RTLIB_DIR=/usr/realtime-2.6.32-122-rtai/modules/emc2
EMC2_CONFIG_DIR=
EMC2_LANG_DIR=/usr/share/emc/tcl/msgs
INIVAR=inivar
HALCMD=halcmd
EMC2_EMCSH=/usr/bin/wish8.5
EMC2 - 2.4.6
Machine configuration directory is '/home/pc/emc2/configs/ma-machine'
Machine configuration file is 'ma-machine.ini'
INIFILE=/home/pc/emc2/configs/ma-machine/ma-machine.ini
PARAMETER_FILE=emc.var
EMCMOT=motmod
EMCIO=io
TASK=milltask
HALUI=
DISPLAY=axis
NML_FILE=
Starting EMC2...
Starting EMC2 server program: emcsvr
Loading Real Time OS, RTAPI, and HAL_LIB modules
Starting EMC2 IO program: io
Starting EMC2 TASK program: milltask
Starting EMC2 DISPLAY program: axis
Shutting down and cleaning up EMC2...
Killing task emcsvr, PID=1593
Killing task milltask, PID=1637
Removing HAL_LIB, RTAPI, and Real Time OS modules
Removing NML shared memory segments
Cleanup done
Debug file information:
/usr/bin/emc: line 654: 1638 Erreur de segmentation $EMCDISPLAY -ini "$INIFILE" $EMCDISPLAYARGS $EXTRA_ARGS
1593
PID TTY STAT TIME COMMAND
1637
Stopping realtime threads
Unloading hal components
Kernel message information:
[ 1263.947156] I-pipe: Domain RTAI registered.
[ 1263.947173] RTAI[hal]: <3.8.1> mounted over IPIPE-NOTHREADS 2.6-03.
[ 1263.947176] RTAI[hal]: compiled with gcc version 4.4.3 (Ubuntu 4.4.3-4ubuntu5) .
[ 1263.947184] RTAI[hal]: mounted (IPIPE-NOTHREADS, IMMEDIATE (INTERNAL IRQs DISPATCHED), ISOL_CPUS_MASK: 0).
[ 1263.947187] PIPELINE layers:
[ 1263.947191] e0ae6e20 9ac15d93 RTAI 200
[ 1263.947195] c085cb20 0 Linux 100
[ 1264.022052] insmod: page allocation failure. order:7, mode:0xd0
[ 1264.022064] Pid: 1609, comm: insmod Not tainted 2.6.32-122-rtai #rtai
[ 1264.022068] Call Trace:
[ 1264.022092] [<c01c4d8e>] __alloc_pages_slowpath+0x46e/0x4a0
[ 1264.022099] [<c01c4efa>] __alloc_pages_nodemask+0x13a/0x170
[ 1264.022104] [<c01c4f4c>] __get_free_pages+0x1c/0x30
[ 1264.022147] [<e0b4c814>] alloc_extent+0x34/0xb0 [rtai_sched]
[ 1264.022158] [<e0b4c9d8>] rtheap_init+0x148/0x230 [rtai_sched]
[ 1264.022169] [<e0b3ed11>] __rtai_lxrt_init+0x41/0x6b0 [rtai_sched]
[ 1264.022174] [<c0101041>] do_one_initcall+0x31/0x1b0
[ 1264.022185] [<e0b3ecd0>] ? __rtai_lxrt_init+0x0/0x6b0 [rtai_sched]
[ 1264.022194] [<c0179781>] sys_init_module+0xb1/0x220
[ 1264.022200] [<c010340d>] syscall_call+0x7/0xb
[ 1264.022204] Mem-Info:
[ 1264.022206] DMA per-cpu:
[ 1264.022209] CPU 0: hi: 0, btch: 1 usd: 0
[ 1264.022212] Normal per-cpu:
[ 1264.022214] CPU 0: hi: 186, btch: 31 usd: 0
[ 1264.022222] active_anon:17285 inactive_anon:19616 isolated_anon:74
[ 1264.022224] active_file:15505 inactive_file:61071 isolated_file:50
[ 1264.022225] unevictable:270 dirty:176 writeback:1705 unstable:0
[ 1264.022227] free:5665 slab_reclaimable:1835 slab_unreclaimable:1804
[ 1264.022228] mapped:15565 shmem:1098 pagetables:1274 bounce:0
[ 1264.022239] DMA free:2016kB min:84kB low:104kB high:124kB active_anon:0kB inactive_anon:0kB active_file:36kB inactive_file:6560kB unevictable:0kB isolated(anon):0kB isolated(file):0kB present:15852kB mlocked:0kB dirty:0kB writeback:0kB mapped:0kB shmem:0kB slab_reclaimable:76kB slab_unreclaimable:4kB kernel_stack:0kB pagetables:0kB unstable:0kB bounce:0kB writeback_tmp:0kB pages_scanned:0 all_unreclaimable? no
[ 1264.022247] lowmem_reserve[]: 0 492 492 492
[ 1264.022259] Normal free:20644kB min:2792kB low:3488kB high:4188kB active_anon:69140kB inactive_anon:78464kB active_file:61984kB inactive_file:237724kB unevictable:1080kB isolated(anon):296kB isolated(file):200kB present:503872kB mlocked:16kB dirty:704kB writeback:6820kB mapped:62260kB shmem:4392kB slab_reclaimable:7264kB slab_unreclaimable:7212kB kernel_stack:1896kB pagetables:5096kB unstable:0kB bounce:0kB writeback_tmp:0kB pages_scanned:0 all_unreclaimable? no
[ 1264.022268] lowmem_reserve[]: 0 0 0 0
[ 1264.022272] DMA: 0*4kB 0*8kB 0*16kB 1*32kB 1*64kB 1*128kB 1*256kB 1*512kB 1*1024kB 0*2048kB 0*4096kB = 2016kB
[ 1264.022285] Normal: 1379*4kB 511*8kB 224*16kB 105*32kB 46*64kB 5*128kB 0*256kB 1*512kB 0*1024kB 0*2048kB 0*4096kB = 20644kB
[ 1264.022298] 80151 total pagecache pages
[ 1264.022300] 2153 pages in swap cache
[ 1264.022303] Swap cache stats: add 2214, delete 61, find 316/316
[ 1264.022305] Free swap = 252400kB
[ 1264.022308] Total swap = 261112kB
[ 1264.030561] 131056 pages RAM
[ 1264.030566] 0 pages HighMem
[ 1264.030569] 3723 pages reserved
[ 1264.030571] 121340 pages shared
[ 1264.030573] 70696 pages non-shared
[ 1264.041646] RTAI[malloc]: global heap size = 2097152 bytes, <BSD>.
[ 1264.044375] RTAI[sched]: IMMEDIATE, MP, USER/KERNEL SPACE: <with RTAI OWN KTASKs>, kstacks pool size = 524288 bytes.
[ 1264.044385] RTAI[sched]: hard timer type/freq = APIC/16738003(Hz); default timing: periodic; linear timed lists.
[ 1264.044389] RTAI[sched]: Linux timer freq = 250 (Hz), TimeBase freq = 1807738000 hz.
[ 1264.044393] RTAI[sched]: timer setup = 999 ns, resched latency = 2944 ns.
[ 1264.047122] RTAI[usi]: enabled.
[ 1264.560533] RTAI[math]: loaded.
[ 1265.094243] config string '0x378 out '
[ 1269.483265] axis[1638]: segfault at 4 ip 00b8aef6 sp bfaaf820 error 4 in libGL.so.1.2[b25000+a7000]
[ 1270.424856] RTAI[math]: unloaded.
[ 1270.543470] SCHED releases registered named ALIEN RTGLBH
[ 1270.558712] RTAI[malloc]: unloaded.
[ 1270.656026] RTAI[sched]: unloaded (forced hard/soft/hard transitions: traps 0, syscalls 0).
[ 1270.666362] I-pipe: Domain RTAI unregistered.
[ 1270.666377] RTAI[hal]: unmounted.
Merci de me venir en aide
TFA
gerard06190
Je ne suis PAS du tout un expert, mais as tu essayé de désinstaller et ré-installer Linux ?
Si tu as téléchargé Linux, as tu vérififié la somme MD5 du CD avant de le graver ?
tfa
bonsoir,
non je n'ai pas fait ça pour l'instant ,mais je vais le faire dès demain peut être que..............?
coredump
On dirait un probleme de mémoire, combien y en a t-il sur ce PC?
jcma
Je ne connais pas EMC2, mais d'apres ton listing, tu a un plantage de LibGL.so. C'est une bibliotheque de gestion graphique (OpenGL).
Il semble y avoir un probleme d'affichage avec EMC2. Regarde du cote du parametrage de l'affichage. Il y a peut-etre un probleme de compatibilite avec ta carte graphique.
EDIT:
Je vient de regarder sur une doc EMC2. Le parametre DISPLAY=axis utilise OpenGL pour gerer l'affichage (D'ailleurs dans ton listing, EMC2 s'arrete apres avoir lancé axis). Essaye de mettre DISPLAY=Tkemc.
Jean-Charles
ewidance
J'ai eu aussi ce genre de pb sur de très vieux pc, avec des drivers graphiques incomplets.
Tu pourrais aussi essayer de passer en VESA (pilote générique), qui passe généralement très bien sous EMC2. C'est pas très performant, mais cela permet de se dépêtrer de galères...
http://forum.ubuntu-fr.org/viewtopic.php?id=356510
tfa
Bonjour ,
Merci pour vos réponses ; pour le moment j'ai partiellement résolu mon problème en remplaçant ce PC par un autre d'occase qui ne sera dédié uniquement à cet usage et qui ne sera pas relié à internet , comme ça j'éviterais (peut être ) d'autres désagréments.
Ceci dit , vu que je ne suis pas le meilleur ,et loin de là , en informatique j'aurais sûrement encore besoin d'aide pour configurer EMC2 pour ma machine.
encore merci et bon après midi.
TFA
bendu73
bendu73
01power
01power
01power
wanfr
vincentimes
vincentimes
web34
web34
web34
