niala003
- 20 Avr 2014
- 26
Bonjours, lorsque je télécharge le dessin pour une scupture avec une fraise de 1/16 ( la scupture pour enlever le brut avec une fraise de 1/4 c'est passer correctement).
Le programme LinuxCNC se ferme et affiche ce message.
N.B. 304 Mo le dessin a scupter
S.V.P. un expert
LinuxCNC Terminated with an error. When reporting problems, please
include all the information below in your message.
Print file information:
RUN_IN_PLACE=no
LINUXCNC_DIR=
LINUXCNC_BIN_DIR=/usr/bin
LINUXCNC_TCL_DIR=/usr/lib/tcltk/linuxcnc
LINUXCNC_SCRIPT_DIR=
LINUXCNC_RTLIB_DIR=/usr/realtime-3.4-9-rtai-686-pae/modules/linuxcnc
LINUXCNC_CONFIG_DIR=
LINUXCNC_LANG_DIR=/usr/share/linuxcnc/tcl/msgs
INIVAR=inivar
HALCMD=halcmd
LINUXCNC_EMCSH=/usr/bin/wish8.5
LINUXCNC - 2.7.0-pre2
Machine configuration directory is '/home/m/linuxcnc/configs/ma-machine_MM'
Machine configuration file is 'ma-machine_MM.ini'
INIFILE=/home/m/linuxcnc/configs/ma-machine_MM/ma-machine_MM.ini
PARAMETER_FILE=linuxcnc.var
TASK=milltask
HALUI=
DISPLAY=axis
Starting LinuxCNC...
Starting LinuxCNC server program: linuxcncsvr
Loading Real Time OS, RTAPI, and HAL_LIB modules
Starting LinuxCNC IO program: io
DELAY=
Starting TASK program: milltask
Starting DISPLAY program: axis
Shutting down and cleaning up LinuxCNC...
Killing task linuxcncsvr, PID=5703
Killing task milltask, PID=5760
Removing HAL_LIB, RTAPI, and Real Time OS modules
Removing NML shared memory segments
Debug file information:
Can not find -sec APPLICATIONS -var DELAY -num 1
/usr/bin/linuxcnc : ligne 811 : 5761 Processus arrêté $EMCDISPLAY -ini "$INIFILE" $EMCDISPLAYARGS $EXTRA_ARGS
5703
PID TTY STAT TIME COMMAND
5760
5760 ? D 0:06 milltask -ini /home/m/linuxcnc/configs/ma-machine_MM/ma-machine_MM.ini
Stopping realtime threads
Unloading hal components
Kernel message information:
[ 0.000000] Initializing cgroup subsys cpuset
[ 0.000000] Linux version 3.4-9-rtai-686-pae (Debian 3.4.55-4linuxcnc) () (gcc version 4.6.3 (Debian 4.6.3-14) ) #1 SMP PREEMPT Debian 3.4.55-4linuxcnc
[ 0.000000] BIOS-provided physical RAM map:
[ 0.000000] BIOS-e820: 0000000000000000 - 000000000009f800 (usable)
[ 0.000000] BIOS-e820: 000000000009f800 - 00000000000a0000 (reserved)
[ 0.000000] BIOS-e820: 00000000000f0000 - 0000000000100000 (reserved)
[ 0.000000] BIOS-e820: 0000000000100000 - 000000003dff0000 (usable)
[ 0.000000] BIOS-e820: 000000003dff0000 - 000000003dff3000 (ACPI NVS)
[ 0.000000] BIOS-e820: 000000003dff3000 - 000000003e000000 (ACPI data)
[ 0.000000] BIOS-e820: 00000000fec00000 - 0000000100000000 (reserved)
[ 0.000000] Notice: NX (Execute Disable) protection cannot be enabled: non-PAE kernel!
[ 0.000000] SMBIOS 2.2 present.
[ 0.000000] DMI: Seanix Technology Inc. /SiS-661, BIOS 6.00 PG 03/07/2005
[ 0.000000] e820 update range: 0000000000000000 - 0000000000010000 (usable) ==> (reserved)
[ 0.000000] e820 remove range: 00000000000a0000 - 0000000000100000 (usable)
[ 0.000000] last_pfn = 0x3dff0 max_arch_pfn = 0x100000
[ 0.000000] MTRR default type: uncachable
[ 0.000000] MTRR fixed ranges enabled:
[ 0.000000] 00000-9FFFF write-back
[ 0.000000] A0000-BFFFF uncachable
[ 0.000000] C0000-C7FFF write-protect
[ 0.000000] C8000-EFFFF uncachable
[ 0.000000] F0000-FFFFF write-through
[ 0.000000] MTRR variable ranges enabled:
[ 0.000000] 0 base 000000000 mask FC0000000 write-back
[ 0.000000] 1 base 03E000000 mask FFE000000 uncachable
[ 0.000000] 2 disabled
[ 0.000000] 3 disabled
[ 0.000000] 4 disabled
[ 0.000000] 5 disabled
[ 0.000000] 6 disabled
[ 0.000000] 7 disabled
[ 0.000000] x86 PAT enabled: cpu 0, old 0x7040600070406, new 0x7010600070106
[ 0.000000] found SMP MP-table at [c00f3cb0] f3cb0
[ 0.000000] initial memory mapped : 0 - 01800000
[ 0.000000] Base memory trampoline at [c009b000] 9b000 size 16384
[ 0.000000] init_memory_mapping: 0000000000000000-00000000377fe000
[ 0.000000] 0000000000 - 0000400000 page 4k
[ 0.000000] 0000400000 - 0037400000 page 2M
[ 0.000000] 0037400000 - 00377fe000 page 4k
[ 0.000000] kernel direct mapping tables up to 0x377fdfff @ [mem 0x017f8000-0x017fffff]
[ 0.000000] RAMDISK: 36534000 - 37292000
[ 0.000000] ACPI: RSDP 000f7d70 00014 (v00 AWARD )
[ 0.000000] ACPI: RSDT 3dff3040 0002C (v01 AWARD AWRDACPI 42302E31 AWRD 00000000)
[ 0.000000] ACPI: FACP 3dff30c0 00074 (v01 AWARD AWRDACPI 42302E31 AWRD 00000000)
[ 0.000000] ACPI: DSDT 3dff3180 03900 (v01 AWARD AWRDACPI 00001000 MSFT 0100000E)
[ 0.000000] ACPI: FACS 3dff0000 00040
[ 0.000000] ACPI: APIC 3dff6ac0 00068 (v01 AWARD AWRDACPI 42302E31 AWRD 00000000)
[ 0.000000] ACPI: Local APIC address 0xfee00000
[ 0.000000] 103MB HIGHMEM available.
[ 0.000000] 887MB LOWMEM available.
[ 0.000000] mapped low ram: 0 - 377fe000
[ 0.000000] low ram: 0 - 377fe000
[ 0.000000] Zone PFN ranges:
[ 0.000000] DMA 0x00000010 -> 0x00001000
[ 0.000000] Normal 0x00001000 -> 0x000377fe
[ 0.000000] HighMem 0x000377fe -> 0x0003dff0
[ 0.000000] Movable zone start PFN for each node
[ 0.000000] Early memory PFN ranges
[ 0.000000] 0: 0x00000010 -> 0x0000009f
[ 0.000000] 0: 0x00000100 -> 0x0003dff0
[ 0.000000] On node 0 totalpages: 253823
[ 0.000000] free_area_init_node: node 0, pgdat c1498a00, node_mem_map f5d74200
[ 0.000000] DMA zone: 32 pages used for memmap
[ 0.000000] DMA zone: 0 pages reserved
[ 0.000000] DMA zone: 3951 pages, LIFO batch:0
[ 0.000000] Normal zone: 1744 pages used for memmap
[ 0.000000] Normal zone: 221486 pages, LIFO batch:31
[ 0.000000] HighMem zone: 208 pages used for memmap
[ 0.000000] HighMem zone: 26402 pages, LIFO batch:7
[ 0.000000] Using APIC driver default
[ 0.000000] ACPI: PM-Timer IO Port: 0x1008
[ 0.000000] ACPI: LAPIC (acpi_id[0x00] lapic_id[0x00] enabled)
[ 0.000000] ACPI: LAPIC (acpi_id[0x01] lapic_id[0x01] disabled)
[ 0.000000] ACPI: LAPIC_NMI (acpi_id[0x00] high edge lint[0x1])
[ 0.000000] ACPI: LAPIC_NMI (acpi_id[0x01] high edge lint[0x1])
[ 0.000000] ACPI: IOAPIC (id[0x02] address[0xfec00000] gsi_base[0])
[ 0.000000] IOAPIC[0]: apic_id 2, version 20, address 0xfec00000, GSI 0-23
[ 0.000000] ACPI: INT_SRC_OVR (bus 0 bus_irq 0 global_irq 2 dfl dfl)
[ 0.000000] ACPI: INT_SRC_OVR (bus 0 bus_irq 9 global_irq 9 dfl dfl)
[ 0.000000] ACPI: IRQ0 used by override.
[ 0.000000] ACPI: IRQ2 used by override.
[ 0.000000] ACPI: IRQ9 used by override.
[ 0.000000] Using ACPI (MADT) for SMP configuration information
[ 0.000000] SMP: Allowing 2 CPUs, 1 hotplug CPUs
[ 0.000000] nr_irqs_gsi: 40
[ 0.000000] PM: Registered nosave memory: 000000000009f000 - 00000000000a0000
[ 0.000000] PM: Registered nosave memory: 00000000000a0000 - 00000000000f0000
[ 0.000000] PM: Registered nosave memory: 00000000000f0000 - 0000000000100000
[ 0.000000] Allocating PCI resources starting at 3e000000 (gap: 3e000000:c0c00000)
[ 0.000000] setup_percpu: NR_CPUS:8 nr_cpumask_bits:8 nr_cpu_ids:2 nr_node_ids:1
[ 0.000000] PERCPU: Embedded 17 pages/cpu @f77d5000 s48384 r0 d21248 u69632
[ 0.000000] pcpu-alloc: s48384 r0 d21248 u69632 alloc=17*4096
[ 0.000000] pcpu-alloc: [0] 0 [0] 1
[ 0.000000] Built 1 zonelists in Zone order, mobility grouping on. Total pages: 251839
[ 0.000000] Kernel command line: BOOT_IMAGE=/boot/vmlinuz-3.4-9-rtai-686-pae root=UUID=1a27a51d-7cdd-4bec-b1e3-f6a7d8a81c83 ro initrd=/install/gtk/initrd.gz lapic quiet rootdelay=5
[ 0.000000] PID hash table entries: 4096 (order: 2, 16384 bytes)
[ 0.000000] Dentry cache hash table entries: 131072 (order: 7, 524288 bytes)
[ 0.000000] Inode-cache hash table entries: 65536 (order: 6, 262144 bytes)
[ 0.000000] Initializing CPU#0
[ 0.000000] allocated 2031360 bytes of page_cgroup
[ 0.000000] please try 'cgroup_disable=memory' option if you don't want memory cgroups
[ 0.000000] Initializing HighMem for node 0 (000377fe:0003dff0)
[ 0.000000] Memory: 984860k/1015744k available (3495k kernel code, 30432k reserved, 1237k data, 416k init, 106440k highmem)
[ 0.000000] virtual kernel memory layout:
[ 0.000000] fixmap : 0xfff17000 - 0xfffff000 ( 928 kB)
[ 0.000000] pkmap : 0xff800000 - 0xffc00000 (4096 kB)
[ 0.000000] vmalloc : 0xf7ffe000 - 0xff7fe000 ( 120 MB)
[ 0.000000] lowmem : 0xc0000000 - 0xf77fe000 ( 887 MB)
[ 0.000000] .init : 0xc14a0000 - 0xc1508000 ( 416 kB)
[ 0.000000] .data : 0xc1369d4a - 0xc149f480 (1237 kB)
[ 0.000000] .text : 0xc1000000 - 0xc1369d4a (3495 kB)
[ 0.000000] Checking if this processor honours the WP bit even in supervisor mode...Ok.
[ 0.000000] Preemptible hierarchical RCU implementation.
[ 0.000000] RCU dyntick-idle grace-period acceleration is enabled.
[ 0.000000] NR_IRQS:2304 nr_irqs:512 16
[ 0.000000] CPU 0 irqstacks, hard=f5808000 soft=f580a000
[ 0.000000] Interrupt pipeline (release #3)
[ 0.000000] Console: colour VGA+ 80x25
[ 0.000000] console [tty0] enabled
[ 0.000000] Fast TSC calibration using PIT
[ 0.000000] Detected 3066.830 MHz processor.
[ 0.008003] Calibrating delay loop (skipped), value calculated using timer frequency.. 6133.66 BogoMIPS (lpj=12267320)
[ 0.008011] pid_max: default: 32768 minimum: 301
[ 0.008090] Security Framework initialized
[ 0.008101] AppArmor: AppArmor disabled by boot time parameter
[ 0.008133] Mount-cache hash table entries: 512
[ 0.008464] Initializing cgroup subsys cpuacct
[ 0.008469] Initializing cgroup subsys memory
[ 0.008485] Initializing cgroup subsys devices
[ 0.008489] Initializing cgroup subsys freezer
[ 0.008493] Initializing cgroup subsys net_cls
[ 0.008496] Initializing cgroup subsys blkio
[ 0.008509] Initializing cgroup subsys perf_event
[ 0.008564] CPU0: Hyper-Threading is disabled
[ 0.008570] mce: CPU supports 4 MCE banks
[ 0.008584] CPU0: Thermal monitoring enabled (TM1)
[ 0.008686] SMP alternatives: switching to UP code
[ 0.014452] ACPI: Core revision 20120320
[ 0.020112] Enabling APIC mode: Flat. Using 1 I/O APICs
[ 0.024168] ..TIMER: vector=0x30 apic1=0 pin1=2 apic2=-1 pin2=-1
[ 0.063854] CPU0: Intel(R) Pentium(R) 4 CPU 3.06GHz stepping 01
[ 0.064003] Performance Events: Netburst events, Netburst P4/Xeon PMU driver.
[ 0.064003] ... version: 0
[ 0.064003] ... bit width: 40
[ 0.064003] ... generic registers: 18
[ 0.064003] ... value mask: 000000ffffffffff
[ 0.064003] ... max period: 0000007fffffffff
[ 0.064003] ... fixed-purpose events: 0
[ 0.064003] ... event mask: 000000000003ffff
[ 0.072042] NMI watchdog: enabled, takes one hw-pmu counter.
[ 0.072102] Brought up 1 CPUs
[ 0.072107] Total of 1 processors activated (6133.66 BogoMIPS).
[ 0.072931] devtmpfs: initialized
[ 0.073355] PM: Registering ACPI NVS region [mem 0x3dff0000-0x3dff2fff] (12288 bytes)
[ 0.073535] dummy:
[ 0.073636] NET: Registered protocol family 16
[ 0.073851] ACPI: bus type pci registered
[ 0.110988] PCI: PCI BIOS revision 2.10 entry at 0xfa580, last bus=1
[ 0.110993] PCI: Using configuration type 1 for base access
[ 0.112026] bio: create slab <bio-0> at 0
[ 0.112183] ACPI: Added _OSI(Module Device)
[ 0.112189] ACPI: Added _OSI(Processor Device)
[ 0.112193] ACPI: Added _OSI(3.0 _SCP Extensions)
[ 0.112198] ACPI: Added _OSI(Processor Aggregator Device)
[ 0.113705] ACPI: EC: Look up EC in DSDT
[ 0.121089] ACPI: Interpreter enabled
[ 0.121112] ACPI: (supports S0 S3 S4 S5)
[ 0.121161] ACPI: Using IOAPIC for interrupt routing
[ 0.128990] ACPI: No dock devices found.
[ 0.129003] PCI: Ignoring host bridge windows from ACPI; if necessary, use "pci=use_crs" and report a bug
[ 0.129123] ACPI: PCI Root Bridge [PCI0] (domain 0000 [bus 00-ff])
[ 0.129297] pci_root PNP0A03:00: host bridge window [io 0x0000-0x047f] (ignored)
[ 0.129302] pci_root PNP0A03:00: host bridge window [io 0x0490-0x0cf7] (ignored)
[ 0.129307] pci_root PNP0A03:00: host bridge window [io 0x0d00-0x0fff] (ignored)
[ 0.129311] pci_root PNP0A03:00: host bridge window [io 0x1100-0xffff] (ignored)
[ 0.129316] pci_root PNP0A03:00: host bridge window [mem 0x000a0000-0x000bffff] (ignored)
[ 0.129320] pci_root PNP0A03:00: host bridge window [mem 0x3e000000-0xfebfffff] (ignored)
[ 0.129325] PCI: root bus 00: using default resources
[ 0.129386] PCI host bridge to bus 0000:00
[ 0.129391] pci_bus 0000:00: root bus resource [io 0x0000-0xffff]
[ 0.129396] pci_bus 0000:00: root bus resource [mem 0x00000000-0xffffffff]
[ 0.129422] pci 0000:00:00.0: [1039] type 00 class 0x060000
[ 0.129440] pci 0000:00:00.0: reg 10: [mem 0xe8000000-0xebffffff]
[ 0.129540] pci 0000:00:01.0: [1039] type 01 class 0x060400
[ 0.129599] pci 0000:00:02.0: [1039] type 00 class 0x060100
[ 0.129718] pci 0000:00:02.5: [1039] type 00 class 0x01018a
[ 0.129755] pci 0000:00:02.5: reg 10: [io 0x01f0-0x01f7]
[ 0.129770] pci 0000:00:02.5: reg 14: [io 0x03f4-0x03f7]
[ 0.129784] pci 0000:00:02.5: reg 18: [io 0x0170-0x0177]
[ 0.129798] pci 0000:00:02.5: reg 1c: [io 0x0374-0x0377]
[ 0.129813] pci 0000:00:02.5: reg 20: [io 0x4000-0x400f]
[ 0.129863] pci 0000:00:02.5: PME# supported from D3cold
[ 0.129895] pci 0000:00:02.7: [1039] type 00 class 0x040100
[ 0.129920] pci 0000:00:02.7: reg 10: [io 0xe000-0xe0ff]
[ 0.129935] pci 0000:00:02.7: reg 14: [io 0xe100-0xe17f]
[ 0.130017] pci 0000:00:02.7: supports D1 D2
[ 0.130021] pci 0000:00:02.7: PME# supported from D3hot D3cold
[ 0.130048] pci 0000:00:03.0: [1039] type 00 class 0x0c0310
[ 0.130069] pci 0000:00:03.0: reg 10: [mem 0xec124000-0xec124fff]
[ 0.130157] pci 0000:00:03.1: [1039] type 00 class 0x0c0310
[ 0.130178] pci 0000:00:03.1: reg 10: [mem 0xec120000-0xec120fff]
[ 0.130268] pci 0000:00:03.2: [1039] type 00 class 0x0c0310
[ 0.130288] pci 0000:00:03.2: reg 10: [mem 0xec121000-0xec121fff]
[ 0.130382] pci 0000:00:03.3: [1039] type 00 class 0x0c0320
[ 0.130406] pci 0000:00:03.3: reg 10: [mem 0xec122000-0xec122fff]
[ 0.130496] pci 0000:00:03.3: PME# supported from D0 D3hot D3cold
[ 0.130534] pci 0000:00:04.0: [1039] type 00 class 0x020000
[ 0.130560] pci 0000:00:04.0: reg 10: [io 0xe200-0xe2ff]
[ 0.130575] pci 0000:00:04.0: reg 14: [mem 0xec123000-0xec123fff]
[ 0.130633] pci 0000:00:04.0: reg 30: [mem 0x00000000-0x0001ffff pref]
[ 0.130661] pci 0000:00:04.0: supports D1 D2
[ 0.130665] pci 0000:00:04.0: PME# supported from D0 D1 D2 D3hot D3cold
[ 0.130693] pci 0000:00:05.0: [1039] type 00 class 0x010185
[ 0.130718] pci 0000:00:05.0: reg 10: [io 0xe300-0xe307]
[ 0.130733] pci 0000:00:05.0: reg 14: [io 0xe400-0xe403]
[ 0.130747] pci 0000:00:05.0: reg 18: [io 0xe500-0xe507]
[ 0.130761] pci 0000:00:05.0: reg 1c: [io 0xe600-0xe603]
[ 0.130776] pci 0000:00:05.0: reg 20: [io 0xe700-0xe70f]
[ 0.130825] pci 0000:00:05.0: PME# supported from D3cold
[ 0.130919] pci 0000:01:00.0: [1039] type 00 class 0x030000
[ 0.130943] pci 0000:01:00.0: reg 10: [mem 0xe0000000-0xe7ffffff pref]
[ 0.130956] pci 0000:01:00.0: reg 14: [mem 0xec000000-0xec01ffff]
[ 0.130969] pci 0000:01:00.0: reg 18: [io 0xd000-0xd07f]
[ 0.131030] pci 0000:01:00.0: supports D1 D2
[ 0.131081] pci 0000:00:01.0: PCI bridge to [bus 01-01]
[ 0.131089] pci 0000:00:01.0: bridge window [io 0xd000-0xdfff]
[ 0.131096] pci 0000:00:01.0: bridge window [mem 0xec000000-0xec0fffff]
[ 0.131103] pci 0000:00:01.0: bridge window [mem 0xe0000000-0xe7ffffff pref]
[ 0.131116] pci_bus 0000:00: on NUMA node 0
[ 0.131123] ACPI: PCI Interrupt Routing Table [\_SB_.PCI0._PRT]
[ 0.131803] pci0000:00: Unable to request _OSC control (_OSC support mask: 0x0e)
[ 0.158103] ACPI: PCI Interrupt Link [LNKA] (IRQs 3 4 *5 6 7 9 10 11 12 14 15)
[ 0.158225] ACPI: PCI Interrupt Link [LNKB] (IRQs 3 4 5 6 7 9 10 *11 12 14 15)
[ 0.158344] ACPI: PCI Interrupt Link [LNKC] (IRQs 3 4 5 6 7 9 10 *11 12 14 15)
[ 0.158466] ACPI: PCI Interrupt Link [LNKD] (IRQs 3 4 5 6 7 9 *10 11 12 14 15)
[ 0.158586] ACPI: PCI Interrupt Link [LNKE] (IRQs 3 4 5 6 7 9 *10 11 12 14 15)
[ 0.158705] ACPI: PCI Interrupt Link [LNKF] (IRQs 3 4 5 6 7 9 10 *11 12 14 15)
[ 0.158830] ACPI: PCI Interrupt Link [LNKG] (IRQs 3 4 *5 6 7 9 10 11 12 14 15)
[ 0.158954] ACPI: PCI Interrupt Link [LNKH] (IRQs 3 4 5 6 7 9 *10 11 12 14 15)
[ 0.159125] vgaarb: device added: PCI:0000:01:00.0,decodes=io+mem,owns=io+mem,locks=none
[ 0.159131] vgaarb: loaded
[ 0.159134] vgaarb: bridge control possible 0000:01:00.0
[ 0.159186] PCI: Using ACPI for IRQ routing
[ 0.159192] PCI: pci_cache_line_size set to 64 bytes
[ 0.159266] reserve RAM buffer: 000000000009f800 - 000000000009ffff
[ 0.159272] reserve RAM buffer: 000000003dff0000 - 000000003fffffff
[ 0.159595] pnp: PnP ACPI init
[ 0.159615] ACPI: bus type pnp registered
[ 0.159940] pnp 00:00: [mem 0x000c8000-0x000cbfff]
[ 0.159946] pnp 00:00: [mem 0x000f0000-0x000f7fff]
[ 0.159950] pnp 00:00: [mem 0x000f8000-0x000fbfff]
[ 0.159953] pnp 00:00: [mem 0x000fc000-0x000fffff]
[ 0.159957] pnp 00:00: [mem 0x3dff0000-0x3dffffff]
[ 0.159961] pnp 00:00: [mem 0xffff0000-0xffffffff]
[ 0.159965] pnp 00:00: [mem 0x00000000-0x0009ffff]
[ 0.159969] pnp 00:00: [mem 0x00100000-0x3dfeffff]
[ 0.159973] pnp 00:00: [mem 0xffee0000-0xffefffff]
[ 0.159977] pnp 00:00: [mem 0xfffe0000-0xfffeffff]
[ 0.159981] pnp 00:00: [mem 0xfec00000-0xfecfffff]
[ 0.159985] pnp 00:00: [mem 0xfee00000-0xfeefffff]
[ 0.160074] system 00:00: [mem 0x000c8000-0x000cbfff] has been reserved
[ 0.160081] system 00:00: [mem 0x000f0000-0x000f7fff] could not be reserved
[ 0.160086] system 00:00: [mem 0x000f8000-0x000fbfff] could not be reserved
[ 0.160091] system 00:00: [mem 0x000fc000-0x000fffff] could not be reserved
[ 0.160097] system 00:00: [mem 0x3dff0000-0x3dffffff] could not be reserved
[ 0.160102] system 00:00: [mem 0xffff0000-0xffffffff] has been reserved
[ 0.160107] system 00:00: [mem 0x00000000-0x0009ffff] could not be reserved
[ 0.160112] system 00:00: [mem 0x00100000-0x3dfeffff] could not be reserved
[ 0.160117] system 00:00: [mem 0xffee0000-0xffefffff] has been reserved
[ 0.160122] system 00:00: [mem 0xfffe0000-0xfffeffff] has been reserved
[ 0.160127] system 00:00: [mem 0xfec00000-0xfecfffff] could not be reserved
[ 0.160132] system 00:00: [mem 0xfee00000-0xfeefffff] has been reserved
[ 0.160138] system 00:00: Plug and Play ACPI device, IDs PNP0c01 (active)
[ 0.160240] pnp 00:01: [bus 00-ff]
[ 0.160245] pnp 00:01: [io 0x0cf8-0x0cff]
[ 0.160250] pnp 00:01: [io 0x0000-0x047f window]
[ 0.160254] pnp 00:01: [io 0x0480-0x048f]
[ 0.160257] pnp 00:01: [io 0x0490-0x0cf7 window]
[ 0.160261] pnp 00:01: [io 0x0d00-0x0fff window]
[ 0.160265] pnp 00:01: [io 0x1000-0x10df]
[ 0.160269] pnp 00:01: [io 0x10e0-0x10ff]
[ 0.160272] pnp 00:01: [io 0x1100-0xffff window]
[ 0.160277] pnp 00:01: [mem 0x000a0000-0x000bffff window]
[ 0.160281] pnp 00:01: [mem 0x3e000000-0xfebfffff window]
[ 0.160343] pnp 00:01: Plug and Play ACPI device, IDs PNP0a03 (active)
[ 0.160809] pnp 00:02: [io 0x0010-0x001f]
[ 0.160813] pnp 00:02: [io 0x0022-0x003f]
[ 0.160817] pnp 00:02: [io 0x0044-0x005f]
[ 0.160821] pnp 00:02: [io 0x0062-0x0063]
[ 0.160824] pnp 00:02: [io 0x0065-0x006f]
[ 0.160828] pnp 00:02: [io 0x0074-0x007f]
[ 0.160832] pnp 00:02: [io 0x0091-0x0093]
[ 0.160835] pnp 00:02: [io 0x00a2-0x00bf]
[ 0.160839] pnp 00:02: [io 0x00e0-0x00ef]
[ 0.160842] pnp 00:02: [io 0x04d0-0x04d1]
[ 0.160848] pnp 00:02: [io 0x0800-0x0805]
[ 0.160852] pnp 00:02: [io 0x0290-0x0297]
[ 0.160928] system 00:02: [io 0x04d0-0x04d1] has been reserved
[ 0.160934] system 00:02: [io 0x0800-0x0805] has been reserved
[ 0.160938] system 00:02: [io 0x0290-0x0297] has been reserved
[ 0.160944] system 00:02: Plug and Play ACPI device, IDs PNP0c02 (active)
[ 0.160975] pnp 00:03: [dma 4]
[ 0.160980] pnp 00:03: [io 0x0000-0x000f]
[ 0.160984] pnp 00:03: [io 0x0080-0x0090]
[ 0.160987] pnp 00:03: [io 0x0094-0x009f]
[ 0.160991] pnp 00:03: [io 0x00c0-0x00df]
[ 0.161057] pnp 00:03: Plug and Play ACPI device, IDs PNP0200 (active)
[ 0.161085] pnp 00:04: [io 0x0070-0x0073]
[ 0.161101] pnp 00:04: [irq 8]
[ 0.161158] pnp 00:04: Plug and Play ACPI device, IDs PNP0b00 (active)
[ 0.161182] pnp 00:05: [io 0x0061]
[ 0.161235] pnp 00:05: Plug and Play ACPI device, IDs PNP0800 (active)
[ 0.161258] pnp 00:06: [io 0x00f0-0x00ff]
[ 0.161266] pnp 00:06: [irq 13]
[ 0.161320] pnp 00:06: Plug and Play ACPI device, IDs PNP0c04 (active)
[ 0.161608] pnp 00:07: [io 0x03f0-0x03f5]
[ 0.161613] pnp 00:07: [io 0x03f7]
[ 0.161621] pnp 00:07: [irq 6]
[ 0.161625] pnp 00:07: [dma 2]
[ 0.161704] pnp 00:07: Plug and Play ACPI device, IDs PNP0700 (active)
[ 0.162073] pnp 00:08: [io 0x03f8-0x03ff]
[ 0.162081] pnp 00:08: [irq 4]
[ 0.162179] pnp 00:08: Plug and Play ACPI device, IDs PNP0501 (active)
[ 0.162578] pnp 00:09: [io 0x02f8-0x02ff]
[ 0.162587] pnp 00:09: [irq 3]
[ 0.162685] pnp 00:09: Plug and Play ACPI device, IDs PNP0501 (active)
[ 0.163112] pnp 00:0a: [io 0x0378-0x037f]
[ 0.163120] pnp 00:0a: [irq 7]
[ 0.163207] pnp 00:0a: Plug and Play ACPI device, IDs PNP0400 (active)
[ 0.163426] pnp 00:0b: [io 0x0060]
[ 0.163431] pnp 00:0b: [io 0x0064]
[ 0.163438] pnp 00:0b: [irq 1]
[ 0.163506] pnp 00:0b: Plug and Play ACPI device, IDs PNP0303 PNP030b (active)
[ 0.163558] pnp: PnP ACPI: found 12 devices
[ 0.163562] ACPI: ACPI bus type pnp unregistered
[ 0.163567] PnPBIOS: Disabled by ACPI PNP
[ 0.201009] Switching to clocksource acpi_pm
[ 0.201064] pci 0000:00:04.0: BAR 6: assigned [mem 0x40000000-0x4001ffff pref]
[ 0.201072] pci 0000:00:01.0: PCI bridge to [bus 01-01]
[ 0.201080] pci 0000:00:01.0: bridge window [io 0xd000-0xdfff]
[ 0.201089] pci 0000:00:01.0: bridge window [mem 0xec000000-0xec0fffff]
[ 0.201096] pci 0000:00:01.0: bridge window [mem 0xe0000000-0xe7ffffff pref]
[ 0.201119] pci_bus 0000:00: resource 4 [io 0x0000-0xffff]
[ 0.201123] pci_bus 0000:00: resource 5 [mem 0x00000000-0xffffffff]
[ 0.201127] pci_bus 0000:01: resource 0 [io 0xd000-0xdfff]
[ 0.201131] pci_bus 0000:01: resource 1 [mem 0xec000000-0xec0fffff]
[ 0.201135] pci_bus 0000:01: resource 2 [mem 0xe0000000-0xe7ffffff pref]
[ 0.201243] NET: Registered protocol family 2
[ 0.201345] IP route cache hash table entries: 32768 (order: 5, 131072 bytes)
[ 0.201749] TCP established hash table entries: 131072 (order: 8, 1048576 bytes)
[ 0.202811] TCP bind hash table entries: 65536 (order: 7, 524288 bytes)
[ 0.203557] TCP: Hash tables configured (established 131072 bind 65536)
[ 0.203563] TCP: reno registered
[ 0.203568] UDP hash table entries: 512 (order: 2, 16384 bytes)
[ 0.203597] UDP-Lite hash table entries: 512 (order: 2, 16384 bytes)
[ 0.203842] NET: Registered protocol family 1
[ 0.368082] pci 0000:01:00.0: Boot video device
[ 0.368089] PCI: CLS 32 bytes, default 64
[ 0.368206] Unpacking initramfs...
[ 0.795111] Freeing initrd memory: 13688k freed
[ 0.816219] audit: initializing netlink socket (disabled)
[ 0.816250] type=2000 audit(1428329918.816:1): initialized
[ 0.831598] highmem bounce pool size: 64 pages
[ 0.831608] HugeTLB registered 4 MB page size, pre-allocated 0 pages
[ 0.831827] VFS: Disk quotas dquot_6.5.2
[ 0.831867] Dquot-cache hash table entries: 1024 (order 0, 4096 bytes)
[ 0.832023] msgmni has been set to 1742
[ 0.832299] alg: No test for stdrng (krng)
[ 0.832343] Block layer SCSI generic (bsg) driver version 0.4 loaded (major 253)
[ 0.832350] io scheduler noop registered
[ 0.832353] io scheduler deadline registered
[ 0.832377] io scheduler cfq registered (default)
[ 0.832512] pci_hotplug: PCI Hot Plug PCI Core version: 0.5
[ 0.832545] pciehp: PCI Express Hot Plug Controller Driver version: 0.4
[ 0.832549] acpiphp: ACPI Hot Plug PCI Controller Driver version: 0.5
[ 0.833243] GHES: HEST is not enabled!
[ 0.833264] isapnp: Scanning for PnP cards...
[ 1.187055] isapnp: No Plug & Play device found
[ 1.187131] Serial: 8250/16550 driver, 4 ports, IRQ sharing enabled
[ 1.207521] serial8250: ttyS0 at I/O 0x3f8 (irq = 4) is a 16550A
[ 1.227908] serial8250: ttyS1 at I/O 0x2f8 (irq = 3) is a 16550A
[ 1.248600] 00:08: ttyS0 at I/O 0x3f8 (irq = 4) is a 16550A
[ 1.269039] 00:09: ttyS1 at I/O 0x2f8 (irq = 3) is a 16550A
[ 1.269238] Linux agpgart interface v0.103
[ 1.269360] agpgart-sis 0000:00:00.0: SiS chipset [1039/0661]
[ 1.274375] agpgart-sis 0000:00:00.0: AGP aperture is 64M @ 0xe8000000
[ 1.274550] i8042: PNP: PS/2 Controller [PNP0303] at 0x60,0x64 irq 1
[ 1.274554] i8042: PNP: PS/2 appears to have AUX port disabled, if this is incorrect please boot with i8042.nopnp
[ 1.274767] serio: i8042 KBD port at 0x60,0x64 irq 1
[ 1.274917] mousedev: PS/2 mouse device common for all mice
[ 1.274994] rtc_cmos 00:04: RTC can wake from S4
[ 1.275159] rtc_cmos 00:04: rtc core: registered rtc_cmos as rtc0
[ 1.275189] rtc0: alarms up to one year, 242 bytes nvram
[ 1.275386] TCP: cubic registered
[ 1.275452] NET: Registered protocol family 10
[ 1.275784] Mobile IPv6
[ 1.275790] NET: Registered protocol family 17
[ 1.275798] Registering the dns_resolver key type
[ 1.275887] Using IPI No-Shortcut mode
[ 1.276070] PM: Hibernation image not present or could not be loaded.
[ 1.276103] registered taskstats version 1
[ 1.276493] rtc_cmos 00:04: setting system clock to 2015-04-06 14:18:39 UTC (1428329919)
[ 1.276622] Freeing unused kernel memory: 416k freed
[ 1.277219] Write protecting the kernel text: 3496k
[ 1.277243] Write protecting the kernel read-only data: 984k
[ 1.300858] udevd[45]: starting version 175
[ 1.302552] input: AT Translated Set 2 keyboard as /devices/platform/i8042/serio0/input/input0
[ 1.386174] SCSI subsystem initialized
[ 1.421332] usbcore: registered new interface driver usbfs
[ 1.421381] usbcore: registered new interface driver hub
[ 1.433799] sis900.c: v1.08.10 Apr. 2 2006
[ 1.434992] 0000:00:04.0: Unknown PHY transceiver found at address 1.
[ 1.444336] ACPI: Fan [FAN] (on)
[ 1.444404] usbcore: registered new device driver usb
[ 1.445157] ehci_hcd: USB 2.0 'Enhanced' Host Controller (EHCI) Driver
[ 1.455565] ohci_hcd: USB 1.1 'Open' Host Controller (OHCI) Driver
[ 1.456357] libata version 3.00 loaded.
[ 1.503859] FDC 0 is a post-1991 82077
[ 1.531934] 0000:00:04.0: Using transceiver found at address 1 as default
[ 1.532999] eth0: SiS 900 PCI Fast Ethernet at 0xe200, IRQ 19, 00:01:6c:a6:78:62
[ 1.541326] microcode: CPU0 sig=0xf41, pf=0x10, revision=0x5
[ 1.547464] ehci_hcd 0000:00:03.3: EHCI Host Controller
[ 1.547514] ehci_hcd 0000:00:03.3: new USB bus registered, assigned bus number 1
[ 1.547606] ehci_hcd 0000:00:03.3: irq 23, io mem 0xec122000
[ 1.556188] ehci_hcd 0000:00:03.3: USB 2.0 started, EHCI 1.00
[ 1.556274] usb usb1: New USB device found, idVendor=1d6b, idProduct=0002
[ 1.556279] usb usb1: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[ 1.556284] usb usb1: Product: EHCI Host Controller
[ 1.556287] usb usb1: Manufacturer: Linux 3.4-9-rtai-686-pae ehci_hcd
[ 1.556291] usb usb1: SerialNumber: 0000:00:03.3
[ 1.556509] hub 1-0:1.0: USB hub found
[ 1.556520] hub 1-0:1.0: 8 ports detected
[ 1.557602] ohci_hcd 0000:00:03.0: OHCI Host Controller
[ 1.557626] ohci_hcd 0000:00:03.0: new USB bus registered, assigned bus number 2
[ 1.557679] ohci_hcd 0000:00:03.0: irq 20, io mem 0xec124000
[ 1.594210] microcode: CPU0 updated to revision 0x17, date = 2005-04-22
[ 1.594697] microcode: Microcode Update Driver: v2.00 <tigran@aivazian.fsnet.co.uk>, Peter Oruba
[ 1.614066] usb usb2: New USB device found, idVendor=1d6b, idProduct=0001
[ 1.614073] usb usb2: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[ 1.614077] usb usb2: Product: OHCI Host Controller
[ 1.614081] usb usb2: Manufacturer: Linux 3.4-9-rtai-686-pae ohci_hcd
[ 1.614085] usb usb2: SerialNumber: 0000:00:03.0
[ 1.614416] hub 2-0:1.0: USB hub found
[ 1.614428] hub 2-0:1.0: 3 ports detected
[ 1.614577] pata_sis 0000:00:02.5: version 0.5.2
[ 1.614669] pata_sis 0000:00:02.5: SiS 962/963 MuTIOL IDE UDMA133 controller
[ 1.615526] scsi0 : pata_sis
[ 1.615763] scsi1 : pata_sis
[ 1.617229] ata1: PATA max UDMA/133 cmd 0x1f0 ctl 0x3f6 bmdma 0x4000 irq 14
[ 1.617234] ata2: PATA max UDMA/133 cmd 0x170 ctl 0x376 bmdma 0x4008 irq 15
[ 1.617994] sata_sis 0000:00:05.0: version 1.0
[ 1.618036] sata_sis 0000:00:05.0: Detected SiS 180/181/964 chipset in SATA mode
[ 1.618931] scsi2 : sata_sis
[ 1.619148] scsi3 : sata_sis
[ 1.619238] ata3: SATA max UDMA/133 cmd 0xe300 ctl 0xe400 bmdma 0xe700 irq 17
[ 1.619246] ata4: SATA max UDMA/133 cmd 0xe500 ctl 0xe600 bmdma 0xe708 irq 17
[ 1.619621] ohci_hcd 0000:00:03.1: OHCI Host Controller
[ 1.619642] ohci_hcd 0000:00:03.1: new USB bus registered, assigned bus number 3
[ 1.619695] ohci_hcd 0000:00:03.1: irq 21, io mem 0xec120000
[ 1.674044] usb usb3: New USB device found, idVendor=1d6b, idProduct=0001
[ 1.674049] usb usb3: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[ 1.674054] usb usb3: Product: OHCI Host Controller
[ 1.674057] usb usb3: Manufacturer: Linux 3.4-9-rtai-686-pae ohci_hcd
[ 1.674061] usb usb3: SerialNumber: 0000:00:03.1
[ 1.675543] hub 3-0:1.0: USB hub found
[ 1.675556] hub 3-0:1.0: 3 ports detected
[ 1.675739] ohci_hcd 0000:00:03.2: OHCI Host Controller
[ 1.675756] ohci_hcd 0000:00:03.2: new USB bus registered, assigned bus number 4
[ 1.675808] ohci_hcd 0000:00:03.2: irq 22, io mem 0xec121000
[ 1.730055] usb usb4: New USB device found, idVendor=1d6b, idProduct=0001
[ 1.730062] usb usb4: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[ 1.730066] usb usb4: Product: OHCI Host Controller
[ 1.730070] usb usb4: Manufacturer: Linux 3.4-9-rtai-686-pae ohci_hcd
[ 1.730074] usb usb4: SerialNumber: 0000:00:03.2
[ 1.731488] hub 4-0:1.0: USB hub found
[ 1.731502] hub 4-0:1.0: 2 ports detected
[ 1.788434] ata1.00: ATA-7: HDS728080PLAT20, PF2OA21B, max UDMA/133
[ 1.788441] ata1.00: 160836480 sectors, multi 16: LBA48
[ 1.812461] ata1.00: configured for UDMA/133
[ 1.812664] scsi 0:0:0:0: Direct-Access ATA HDS728080PLAT20 PF2O PQ: 0 ANSI: 5
[ 1.824090] Refined TSC clocksource calibration: 3066.775 MHz.
[ 1.824101] Switching to clocksource tsc
[ 1.946908] ata3: SATA link down (SStatus 0 SControl 300)
[ 1.976264] ata2.01: ATAPI: HL-DT-ST DVDRAM GSA-4160B, A300, max UDMA/66
[ 1.992262] ata2.01: configured for UDMA/66
[ 1.997970] scsi 1:0:1:0: CD-ROM HL-DT-ST DVDRAM GSA-4160B A300 PQ: 0 ANSI: 5
[ 2.104023] usb 4-1: new low-speed USB device number 2 using ohci_hcd
[ 2.326908] ata4: SATA link down (SStatus 0 SControl 300)
[ 2.328957] usb 4-1: New USB device found, idVendor=046d, idProduct=c00c
[ 2.328962] usb 4-1: New USB device strings: Mfr=1, Product=2, SerialNumber=0
[ 2.328967] usb 4-1: Product: USB Mouse
[ 2.328970] usb 4-1: Manufacturer: Logitech
[ 2.363253] input: Logitech USB Mouse as /devices/pci0000:00/0000:00:03.2/usb4/4-1/4-1:1.0/input/input1
[ 2.363504] generic-usb 0003:046D:C00C.0001: input,hidraw0: USB HID v1.10 Mouse [Logitech USB Mouse] on usb-0000:00:03.2-1/input0
[ 2.363633] usbcore: registered new interface driver usbhid
[ 2.363638] usbhid: USB HID core driver
[ 2.366426] sd 0:0:0:0: [sda] 160836480 512-byte logical blocks: (82.3 GB/76.6 GiB)
[ 2.366541] sd 0:0:0:0: [sda] Write Protect is off
[ 2.366546] sd 0:0:0:0: [sda] Mode Sense: 00 3a 00 00
[ 2.366595] sd 0:0:0:0: [sda] Write cache: enabled, read cache: enabled, doesn't support DPO or FUA
[ 2.368640] sr0: scsi3-mmc drive: 40x/40x writer dvd-ram cd/rw xa/form2 cdda tray
[ 2.368649] cdrom: Uniform CD-ROM driver Revision: 3.20
[ 2.369397] sr 1:0:1:0: Attached scsi CD-ROM sr0
[ 2.397186] sda: sda1 sda2 < sda5 >
[ 2.397785] sd 0:0:0:0: [sda] Attached SCSI disk
[ 2.406831] sd 0:0:0:0: Attached scsi generic sg0 type 0
[ 2.407574] sr 1:0:1:0: Attached scsi generic sg1 type 5
[ 7.747870] PM: Starting manual resume from disk
[ 7.747878] PM: Hibernation image partition 8:5 present
[ 7.747882] PM: Looking for hibernation image.
[ 7.762898] PM: Image not found (code -22)
[ 7.762902] PM: Hibernation image not present or could not be loaded.
[ 7.823837] EXT4-fs (sda1): mounted filesystem with ordered data mode. Opts: (null)
[ 9.860700] udevd[337]: starting version 175
[ 10.173437] input: Power Button as /devices/LNXSYSTM:00/LNXSYBUS:00/PNP0C0C:00/input/input2
[ 10.173451] ACPI: Power Button [PWRB]
[ 10.173567] input: Power Button as /devices/LNXSYSTM:00/LNXPWRBN:00/input/input3
[ 10.173574] ACPI: Power Button [PWRF]
[ 10.223550] parport_pc 00:0a: reported by Plug and Play ACPI
[ 10.223602] parport0: PC-style at 0x378, irq 7 [PCSPP,TRISTATE]
[ 10.248289] shpchp: Standard Hot Plug PCI Controller Driver version: 0.4
[ 11.140030] intel8x0_measure_ac97_clock: measured 54743 usecs (2634 samples)
[ 11.140037] intel8x0: clocking to 48000
[ 12.899962] Adding 2028540k swap on /dev/sda5. Priority:-1 extents:1 across:2028540k
[ 12.924446] EXT4-fs (sda1): re-mounted. Opts: (null)
[ 13.179391] EXT4-fs (sda1): re-mounted. Opts: errors=remount-ro
[ 13.332520] loop: module loaded
[ 15.361324] RPC: Registered named UNIX socket transport module.
[ 15.361331] RPC: Registered udp transport module.
[ 15.361334] RPC: Registered tcp transport module.
[ 15.361337] RPC: Registered tcp NFSv4.1 backchannel transport module.
[ 15.398703] FS-Cache: Loaded
[ 15.441808] NFS: Registering the id_resolver key type
[ 15.441856] FS-Cache: Netfs 'nfs' registered for caching
[ 15.461576] Installing knfsd (copyright (C) 1996 okir@monad.swb.de).
[ 17.672366] input: ACPI Virtual Keyboard Device as /devices/virtual/input/input4
[ 18.750924] Bluetooth: Core ver 2.16
[ 18.751259] NET: Registered protocol family 31
[ 18.751264] Bluetooth: HCI device and connection manager initialized
[ 18.751268] Bluetooth: HCI socket layer initialized
[ 18.751272] Bluetooth: L2CAP socket layer initialized
[ 18.751282] Bluetooth: SCO socket layer initialized
[ 18.811925] Bluetooth: RFCOMM TTY layer initialized
[ 18.811937] Bluetooth: RFCOMM socket layer initialized
[ 18.811942] Bluetooth: RFCOMM ver 1.11
[ 18.858488] Bluetooth: BNEP (Ethernet Emulation) ver 1.3
[ 18.858495] Bluetooth: BNEP filters: protocol multicast
[ 18.959233] lp0: using parport0 (interrupt-driven).
[ 19.146324] ppdev: user-space parallel port driver
[ 21.978317] ADDRCONF(NETDEV_UP): eth0: link is not ready
[ 368.797472] I-pipe: head domain RTAI registered.
[ 368.797484] RTAI[hal]: compiled with gcc version 4.7.2 (Debian 4.7.2-5) .
[ 368.797493] RTAI[hal]: mounted (IPIPE-NOTHREADS, IMMEDIATE (INTERNAL IRQs DISPATCHED), ISOL_CPUS_MASK: 0).
[ 368.797499] SYSINFO: CPUs 1, LINUX APIC IRQ 2312, TIM_FREQ 8333578, CLK_FREQ 3066830000, CPU_FREQ 3066830000
[ 368.797503] RTAI_APIC_TIMER_IPI: RTAI DEFINED 2314, VECTOR 2314; LINUX_APIC_TIMER_IPI: RTAI DEFINED 2312, VECTOR 2312
[ 368.797508] TIMER NAME: lapic; VARIOUSLY FOUND APIC FREQs: 8333578, 8333578, 8286500
[ 368.862710] RTAI[malloc]: global heap size = 2097152 bytes, <BSD>.
[ 368.862791] , <uses LINUX SYSCALLs>, kstacks pool size = 524288 bytes.
[ 368.862799] RTAI[sched]: hard timer type/freq = APIC/8333578(Hz); default timing: oneshot; linear timed lists.
[ 368.862804] RTAI[sched]: Linux timer freq = 250 (Hz), TimeBase freq = 3066830000 hz.
[ 368.862808] RTAI[sched]: timer setup = 999 ns, resched latency = 2944 ns.
[ 368.889413] RTAI[math]: loaded.
[ 369.443877] RTAPI: ERROR: Unexpected realtime delay on task 1
[ 369.443882] This Message will only display once per session.
[ 369.443884] Run the Latency Test and resolve before continuing.
[ 382.899139] RTAI[math]: unloaded.
[ 382.902775] SCHED releases registered named ALIEN PEDV$D
[ 382.912173] RTAI[malloc]: unloaded.
[ 383.012025] RTAI[sched]: unloaded (forced hard/soft/hard transitions: traps 0, syscalls 0).
[ 383.015714] I-pipe: head domain RTAI unregistered.
[ 383.015733] RTAI[hal]: unmounted.
[ 535.984327] I-pipe: head domain RTAI registered.
[ 535.984337] RTAI[hal]: compiled with gcc version 4.7.2 (Debian 4.7.2-5) .
[ 535.984346] RTAI[hal]: mounted (IPIPE-NOTHREADS, IMMEDIATE (INTERNAL IRQs DISPATCHED), ISOL_CPUS_MASK: 0).
[ 535.984352] SYSINFO: CPUs 1, LINUX APIC IRQ 2312, TIM_FREQ 8333578, CLK_FREQ 3066830000, CPU_FREQ 3066830000
[ 535.984356] RTAI_APIC_TIMER_IPI: RTAI DEFINED 2314, VECTOR 2314; LINUX_APIC_TIMER_IPI: RTAI DEFINED 2312, VECTOR 2312
[ 535.984361] TIMER NAME: lapic; VARIOUSLY FOUND APIC FREQs: 8333578, 8333578, 8257250
[ 536.000519] RTAI[malloc]: global heap size = 2097152 bytes, <BSD>.
[ 536.000595] , <uses LINUX SYSCALLs>, kstacks pool size = 524288 bytes.
[ 536.000604] RTAI[sched]: hard timer type/freq = APIC/8333578(Hz); default timing: oneshot; linear timed lists.
[ 536.000609] RTAI[sched]: Linux timer freq = 250 (Hz), TimeBase freq = 3066830000 hz.
[ 536.000613] RTAI[sched]: timer setup = 999 ns, resched latency = 2944 ns.
[ 536.017985] RTAI[math]: loaded.
[ 536.208679] config string '0x378 out'
[ 540.301671] spurious APIC interrupt on CPU#0, should never happen.
[ 540.308630] RTAI[math]: unloaded.
[ 540.312683] SCHED releases registered named ALIEN PEDV$D
[ 540.322599] RTAI[malloc]: unloaded.
[ 540.420026] RTAI[sched]: unloaded (forced hard/soft/hard transitions: traps 0, syscalls 0).
[ 540.423021] I-pipe: head domain RTAI unregistered.
[ 540.423039] RTAI[hal]: unmounted.
[ 574.810240] I-pipe: head domain RTAI registered.
[ 574.810251] RTAI[hal]: compiled with gcc version 4.7.2 (Debian 4.7.2-5) .
[ 574.810261] RTAI[hal]: mounted (IPIPE-NOTHREADS, IMMEDIATE (INTERNAL IRQs DISPATCHED), ISOL_CPUS_MASK: 0).
[ 574.810267] SYSINFO: CPUs 1, LINUX APIC IRQ 2312, TIM_FREQ 8333578, CLK_FREQ 3066830000, CPU_FREQ 3066830000
[ 574.810271] RTAI_APIC_TIMER_IPI: RTAI DEFINED 2314, VECTOR 2314; LINUX_APIC_TIMER_IPI: RTAI DEFINED 2312, VECTOR 2312
[ 574.810276] TIMER NAME: lapic; VARIOUSLY FOUND APIC FREQs: 8333578, 8333578, 8259500
[ 574.829250] RTAI[malloc]: global heap size = 2097152 bytes, <BSD>.
[ 574.829327] , <uses LINUX SYSCALLs>, kstacks pool size = 524288 bytes.
[ 574.829335] RTAI[sched]: hard timer type/freq = APIC/8333578(Hz); default timing: oneshot; linear timed lists.
[ 574.829341] RTAI[sched]: Linux timer freq = 250 (Hz), TimeBase freq = 3066830000 hz.
[ 574.829344] RTAI[sched]: timer setup = 999 ns, resched latency = 2944 ns.
[ 574.843476] RTAI[math]: loaded.
[ 575.096039] config string '0x378 out'
[ 1047.087021] RTAI[math]: unloaded.
[ 1047.093473] SCHED releases registered named ALIEN PEDV$D
[ 1047.102822] RTAI[malloc]: unloaded.
[ 1047.200022] RTAI[sched]: unloaded (forced hard/soft/hard transitions: traps 0, syscalls 0).
[ 1047.203529] I-pipe: head domain RTAI unregistered.
[ 1047.203547] RTAI[hal]: unmounted.
[ 1074.251291] I-pipe: head domain RTAI registered.
[ 1074.251303] RTAI[hal]: compiled with gcc version 4.7.2 (Debian 4.7.2-5) .
[ 1074.251313] RTAI[hal]: mounted (IPIPE-NOTHREADS, IMMEDIATE (INTERNAL IRQs DISPATCHED), ISOL_CPUS_MASK: 0).
[ 1074.251318] SYSINFO: CPUs 1, LINUX APIC IRQ 2312, TIM_FREQ 8333578, CLK_FREQ 3066830000, CPU_FREQ 3066830000
[ 1074.251323] RTAI_APIC_TIMER_IPI: RTAI DEFINED 2314, VECTOR 2314; LINUX_APIC_TIMER_IPI: RTAI DEFINED 2312, VECTOR 2312
[ 1074.251328] TIMER NAME: lapic; VARIOUSLY FOUND APIC FREQs: 8333578, 8333578, 8263000
[ 1074.270005] RTAI[malloc]: global heap size = 2097152 bytes, <BSD>.
[ 1074.270086] , <uses LINUX SYSCALLs>, kstacks pool size = 524288 bytes.
[ 1074.270094] RTAI[sched]: hard timer type/freq = APIC/8333578(Hz); default timing: oneshot; linear timed lists.
[ 1074.270100] RTAI[sched]: Linux timer freq = 250 (Hz), TimeBase freq = 3066830000 hz.
[ 1074.270103] RTAI[sched]: timer setup = 999 ns, resched latency = 2944 ns.
[ 1074.290435] RTAI[math]: loaded.
[ 1074.436473] config string '0x378 out'
[ 1088.798730] RTAI[math]: unloaded.
[ 1088.805080] SCHED releases registered named ALIEN PEDV$D
[ 1088.814550] RTAI[malloc]: unloaded.
[ 1088.912046] RTAI[sched]: unloaded (forced hard/soft/hard transitions: traps 0, syscalls 0).
[ 1088.915046] I-pipe: head domain RTAI unregistered.
[ 1088.915063] RTAI[hal]: unmounted.
[ 1097.512976] I-pipe: head domain RTAI registered.
[ 1097.512987] RTAI[hal]: compiled with gcc version 4.7.2 (Debian 4.7.2-5) .
[ 1097.512996] RTAI[hal]: mounted (IPIPE-NOTHREADS, IMMEDIATE (INTERNAL IRQs DISPATCHED), ISOL_CPUS_MASK: 0).
[ 1097.513001] SYSINFO: CPUs 1, LINUX APIC IRQ 2312, TIM_FREQ 8333578, CLK_FREQ 3066830000, CPU_FREQ 3066830000
[ 1097.513006] RTAI_APIC_TIMER_IPI: RTAI DEFINED 2314, VECTOR 2314; LINUX_APIC_TIMER_IPI: RTAI DEFINED 2312, VECTOR 2312
[ 1097.513011] TIMER NAME: lapic; VARIOUSLY FOUND APIC FREQs: 8333578, 8333578, 8256750
[ 1097.530768] RTAI[malloc]: global heap size = 2097152 bytes, <BSD>.
[ 1097.530845] , <uses LINUX SYSCALLs>, kstacks pool size = 524288 bytes.
[ 1097.530853] RTAI[sched]: hard timer type/freq = APIC/8333578(Hz); default timing: oneshot; linear timed lists.
[ 1097.530858] RTAI[sched]: Linux timer freq = 250 (Hz), TimeBase freq = 3066830000 hz.
[ 1097.530862] RTAI[sched]: timer setup = 999 ns, resched latency = 2944 ns.
[ 1097.551331] RTAI[math]: loaded.
[ 1097.697686] config string '0x378 out'
[ 1105.637350] RTAI[math]: unloaded.
[ 1105.640992] SCHED releases registered named ALIEN PEDV$D
[ 1105.650398] RTAI[malloc]: unloaded.
[ 1105.748024] RTAI[sched]: unloaded (forced hard/soft/hard transitions: traps 0, syscalls 0).
[ 1105.751057] I-pipe: head domain RTAI unregistered.
[ 1105.751075] RTAI[hal]: unmounted.
[ 1114.147803] I-pipe: head domain RTAI registered.
[ 1114.147814] RTAI[hal]: compiled with gcc version 4.7.2 (Debian 4.7.2-5) .
[ 1114.147824] RTAI[hal]: mounted (IPIPE-NOTHREADS, IMMEDIATE (INTERNAL IRQs DISPATCHED), ISOL_CPUS_MASK: 0).
[ 1114.147830] SYSINFO: CPUs 1, LINUX APIC IRQ 2312, TIM_FREQ 8333578, CLK_FREQ 3066830000, CPU_FREQ 3066830000
[ 1114.147834] RTAI_APIC_TIMER_IPI: RTAI DEFINED 2314, VECTOR 2314; LINUX_APIC_TIMER_IPI: RTAI DEFINED 2312, VECTOR 2312
[ 1114.147839] TIMER NAME: lapic; VARIOUSLY FOUND APIC FREQs: 8333578, 8333578, 8274750
[ 1114.165983] RTAI[malloc]: global heap size = 2097152 bytes, <BSD>.
[ 1114.166061] , <uses LINUX SYSCALLs>, kstacks pool size = 524288 bytes.
[ 1114.166069] RTAI[sched]: hard timer type/freq = APIC/8333578(Hz); default timing: oneshot; linear timed lists.
[ 1114.166075] RTAI[sched]: Linux timer freq = 250 (Hz), TimeBase freq = 3066830000 hz.
[ 1114.166079] RTAI[sched]: timer setup = 999 ns, resched latency = 2944 ns.
[ 1114.182014] RTAI[math]: loaded.
[ 1114.332805] config string '0x378 out'
[ 1122.616979] RTAI[math]: unloaded.
[ 1122.623405] SCHED releases registered named ALIEN PEDV$D
[ 1122.633786] RTAI[malloc]: unloaded.
[ 1122.732029] RTAI[sched]: unloaded (forced hard/soft/hard transitions: traps 0, syscalls 0).
[ 1122.735858] I-pipe: head domain RTAI unregistered.
[ 1122.735877] RTAI[hal]: unmounted.
[ 1132.551658] I-pipe: head domain RTAI registered.
[ 1132.551670] RTAI[hal]: compiled with gcc version 4.7.2 (Debian 4.7.2-5) .
[ 1132.551680] RTAI[hal]: mounted (IPIPE-NOTHREADS, IMMEDIATE (INTERNAL IRQs DISPATCHED), ISOL_CPUS_MASK: 0).
[ 1132.551685] SYSINFO: CPUs 1, LINUX APIC IRQ 2312, TIM_FREQ 8333578, CLK_FREQ 3066830000, CPU_FREQ 3066830000
[ 1132.551690] RTAI_APIC_TIMER_IPI: RTAI DEFINED 2314, VECTOR 2314; LINUX_APIC_TIMER_IPI: RTAI DEFINED 2312, VECTOR 2312
[ 1132.551695] TIMER NAME: lapic; VARIOUSLY FOUND APIC FREQs: 8333578, 8333578, 8279750
[ 1132.567993] RTAI[malloc]: global heap size = 2097152 bytes, <BSD>.
[ 1132.568350] , <uses LINUX SYSCALLs>, kstacks pool size = 524288 bytes.
[ 1132.568360] RTAI[sched]: hard timer type/freq = APIC/8333578(Hz); default timing: oneshot; linear timed lists.
[ 1132.568366] RTAI[sched]: Linux timer freq = 250 (Hz), TimeBase freq = 3066830000 hz.
[ 1132.568369] RTAI[sched]: timer setup = 999 ns, resched latency = 2944 ns.
[ 1132.582602] RTAI[math]: loaded.
[ 1132.728736] config string '0x378 out'
[ 1141.122307] RTAI[math]: unloaded.
[ 1141.125958] SCHED releases registered named ALIEN PEDV$D
[ 1141.135266] RTAI[malloc]: unloaded.
[ 1141.232024] RTAI[sched]: unloaded (forced hard/soft/hard transitions: traps 0, syscalls 0).
[ 1141.235000] I-pipe: head domain RTAI unregistered.
[ 1141.235020] RTAI[hal]: unmounted.
[ 5422.612026] usb 1-6: new high-speed USB device number 3 using ehci_hcd
[ 5422.777563] usb 1-6: New USB device found, idVendor=0781, idProduct=5581
[ 5422.777570] usb 1-6: New USB device strings: Mfr=1, Product=2, SerialNumber=3
[ 5422.777574] usb 1-6: Product: SanDisk Ultra
[ 5422.777578] usb 1-6: Manufacturer: SanDisk
[ 5422.777581] usb 1-6: SerialNumber: A20052C5D15E8F53
[ 5422.868783] Initializing USB Mass Storage driver...
[ 5422.868960] scsi4 : usb-storage 1-6:1.0
[ 5422.869528] usbcore: registered new interface driver usb-storage
[ 5422.869533] USB Mass Storage support registered.
[ 5423.868790] scsi 4:0:0:0: Direct-Access SanDisk SanDisk Ultra PMAP PQ: 0 ANSI: 6
[ 5423.874179] sd 4:0:0:0: Attached scsi generic sg2 type 0
[ 5423.874523] sd 4:0:0:0: [sdb] 123502592 512-byte logical blocks: (63.2 GB/58.8 GiB)
[ 5423.875655] sd 4:0:0:0: [sdb] Write Protect is off
[ 5423.875663] sd 4:0:0:0: [sdb] Mode Sense: 2b 00 00 08
[ 5423.876782] sd 4:0:0:0: [sdb] Write cache: disabled, read cache: enabled, doesn't support DPO or FUA
[ 5424.076245] sdb: sdb1
[ 5424.082124] sd 4:0:0:0: [sdb] Attached SCSI removable disk
[ 5435.322610] I-pipe: head domain RTAI registered.
[ 5435.322622] RTAI[hal]: compiled with gcc version 4.7.2 (Debian 4.7.2-5) .
[ 5435.322632] RTAI[hal]: mounted (IPIPE-NOTHREADS, IMMEDIATE (INTERNAL IRQs DISPATCHED), ISOL_CPUS_MASK: 0).
[ 5435.322637] SYSINFO: CPUs 1, LINUX APIC IRQ 2312, TIM_FREQ 8333578, CLK_FREQ 3066830000, CPU_FREQ 3066830000
[ 5435.322642] RTAI_APIC_TIMER_IPI: RTAI DEFINED 2314, VECTOR 2314; LINUX_APIC_TIMER_IPI: RTAI DEFINED 2312, VECTOR 2312
[ 5435.322646] TIMER NAME: lapic; VARIOUSLY FOUND APIC FREQs: 8333578, 8333578, 8252500
[ 5435.345221] RTAI[malloc]: global heap size = 2097152 bytes, <BSD>.
[ 5435.345297] , <uses LINUX SYSCALLs>, kstacks pool size = 524288 bytes.
[ 5435.345306] RTAI[sched]: hard timer type/freq = APIC/8333578(Hz); default timing: oneshot; linear timed lists.
[ 5435.345311] RTAI[sched]: Linux timer freq = 250 (Hz), TimeBase freq = 3066830000 hz.
[ 5435.345315] RTAI[sched]: timer setup = 999 ns, resched latency = 2944 ns.
[ 5435.359630] RTAI[math]: loaded.
[ 5435.548911] config string '0x378 out'
[ 5464.964218] usb 1-6: USB disconnect, device number 3
[ 6153.208073] usb 1-5: new high-speed USB device number 4 using ehci_hcd
[ 6153.411415] usb 1-5: New USB device found, idVendor=058f, idProduct=6387
[ 6153.411423] usb 1-5: New USB device strings: Mfr=1, Product=2, SerialNumber=3
[ 6153.411428] usb 1-5: Product: Mass Storage
[ 6153.411432] usb 1-5: Manufacturer: Generic
[ 6153.411435] usb 1-5: SerialNumber: B475869A
[ 6153.413320] scsi5 : usb-storage 1-5:1.0
[ 6154.416794] scsi 5:0:0:0: Direct-Access Generic Flash Disk 8.07 PQ: 0 ANSI: 4
[ 6154.423815] sd 5:0:0:0: Attached scsi generic sg2 type 0
[ 6154.425010] sd 5:0:0:0: [sdb] 7989248 512-byte logical blocks: (4.09 GB/3.80 GiB)
[ 6154.426024] sd 5:0:0:0: [sdb] Write Protect is off
[ 6154.426032] sd 5:0:0:0: [sdb] Mode Sense: 23 00 00 00
[ 6154.427000] sd 5:0:0:0: [sdb] Write cache: disabled, read cache: enabled, doesn't support DPO or FUA
[ 6154.909959] sdb: sdb1
[ 6154.915185] sd 5:0:0:0: [sdb] Attached SCSI removable disk
[ 6157.832019] FAT-fs (sdb1): utf8 is not a recommended IO charset for FAT filesystems, filesystem will be case sensitive!
[24299.125541] RTAI[math]: unloaded.
[24299.130575] SCHED releases registered named ALIEN PEDV$D
[24299.141348] RTAI[malloc]: unloaded.
[24299.240085] RTAI[sched]: unloaded (forced hard/soft/hard transitions: traps 0, syscalls 0).
[24299.244812] I-pipe: head domain RTAI unregistered.
[24299.244829] RTAI[hal]: unmounted.
[24371.075647] I-pipe: head domain RTAI registered.
[24371.075660] RTAI[hal]: compiled with gcc version 4.7.2 (Debian 4.7.2-5) .
[24371.075669] RTAI[hal]: mounted (IPIPE-NOTHREADS, IMMEDIATE (INTERNAL IRQs DISPATCHED), ISOL_CPUS_MASK: 0).
[24371.075675] SYSINFO: CPUs 1, LINUX APIC IRQ 2312, TIM_FREQ 8333578, CLK_FREQ 3066830000, CPU_FREQ 3066830000
[24371.075679] RTAI_APIC_TIMER_IPI: RTAI DEFINED 2314, VECTOR 2314; LINUX_APIC_TIMER_IPI: RTAI DEFINED 2312, VECTOR 2312
[24371.075684] TIMER NAME: lapic; VARIOUSLY FOUND APIC FREQs: 8333578, 8333578, 8269750
[24371.093427] RTAI[malloc]: global heap size = 2097152 bytes, <BSD>.
[24371.093507] , <uses LINUX SYSCALLs>, kstacks pool size = 524288 bytes.
[24371.093516] RTAI[sched]: hard timer type/freq = APIC/8333578(Hz); default timing: oneshot; linear timed lists.
[24371.093521] RTAI[sched]: Linux timer freq = 250 (Hz), TimeBase freq = 3066830000 hz.
[24371.093525] RTAI[sched]: timer setup = 999 ns, resched latency = 2944 ns.
[24371.114408] RTAI[math]: loaded.
[24371.315615] config string '0x378 out'
[24375.968371] RTAPI: ERROR: Unexpected realtime delay on task 1
[24375.968382] This Message will only display once per session.
[24375.968384] Run the Latency Test and resolve before continuing.
[25088.504594] Xorg invoked oom-killer: gfp_mask=0x201da, order=0, oom_adj=0, oom_score_adj=0
[25088.504605] Xorg cpuset=/ mems_allowed=0
[25088.504612] Pid: 2838, comm: Xorg Tainted: G O 3.4-9-rtai-686-pae #1
[25088.504623] Call Trace:
[25088.504642] [<c135eef8>] ? dump_header.isra.7+0x7e/0x1d3
[25088.504661] [<c101b03b>] ? __ipipe_handle_irq+0x5b/0x160
[25088.504669] [<c1364195>] ? ipipe_hrtimer_interrupt+0x31/0x40
[25088.504682] [<c1363d5c>] ? _raw_spin_unlock_irqrestore+0x1c/0x40
[25088.504691] [<c11ae8ff>] ? ___ratelimit+0xcf/0x140
[25088.504700] [<c1154314>] ? security_capable_noaudit+0x14/0x20
[25088.504718] [<c10ace93>] ? oom_kill_process+0x273/0x2b0
[25088.504724] [<c10acbdb>] ? oom_badness+0xbb/0x100
[25088.504729] [<c10ad362>] ? out_of_memory+0x142/0x1b0
[25088.504744] [<c10b12db>] ? __alloc_pages_nodemask+0x7bb/0x7d0
[25088.504751] [<c10ac13f>] ? filemap_fault+0x2af/0x400
[25088.504759] [<c10c275f>] ? __do_fault+0x5f/0x4a0
[25088.504773] [<c10c54bb>] ? handle_pte_fault+0x8b/0x890
[25088.504780] [<c1367107>] ? sub_preempt_count+0x67/0xa0
[25088.504788] [<c1009b03>] ? restore_i387_fxsave+0x73/0x80
[25088.504803] [<c104ec08>] ? get_parent_ip+0x8/0x20
[25088.504810] [<c10c5d78>] ? handle_mm_fault+0xb8/0x120
[25088.504815] [<c1366bf2>] ? do_page_fault+0x112/0x4b0
[25088.504821] [<c100a7f4>] ? restore_i387_xstate+0x104/0x280
[25088.504936] [<c1003c10>] ? arch_irq_stat+0x10/0x10
[25088.504955] [<f84e942e>] ? rtai_hirq_dispatcher+0x8e/0x180 [rtai_hal]
[25088.504964] [<c103697f>] ? recalc_sigpending+0xf/0x40
[25088.504969] [<c101ac60>] ? __ipipe_handle_exception+0xd0/0x230
[25088.504983] [<c13647f0>] ? error_code+0x6c/0x7c
[25088.504988] Mem-Info:
[25088.504991] DMA per-cpu:
[25088.504995] CPU 0: hi: 0, btch: 1 usd: 0
[25088.504998] Normal per-cpu:
[25088.505008] CPU 0: hi: 186, btch: 31 usd: 201
[25088.505012] HighMem per-cpu:
[25088.505015] CPU 0: hi: 42, btch: 7 usd: 35
[25088.505021] active_anon:119417 inactive_anon:119535 isolated_anon:0
[25088.505023] active_file:92 inactive_file:411 isolated_file:0
[25088.505024] unevictable:0 dirty:0 writeback:0 unstable:0
[25088.505026] free:2755 slab_reclaimable:881 slab_unreclaimable:1810
[25088.505027] mapped:768 shmem:40 pagetables:1199 bounce:0
[25088.505042] DMA free:3932kB min:64kB low:80kB high:96kB active_anon:5872kB inactive_anon:6072kB active_file:0kB inactive_file:24kB unevictable:0kB isolated(anon):0kB isolated(file):0kB present:15804kB mlocked:0kB dirty:0kB writeback:0kB mapped:0kB shmem:0kB slab_reclaimable:0kB slab_unreclaimable:0kB kernel_stack:0kB pagetables:8kB unstable:0kB bounce:0kB writeback_tmp:0kB pages_scanned:30 all_unreclaimable? yes
[25088.505050] lowmem_reserve[]: 0 865 968 968
[25088.505070] Normal free:6980kB min:3728kB low:4660kB high:5592kB active_anon:423868kB inactive_anon:424092kB active_file:352kB inactive_file:1548kB unevictable:0kB isolated(anon):0kB isolated(file):0kB present:885944kB mlocked:0kB dirty:0kB writeback:0kB mapped:496kB shmem:144kB slab_reclaimable:3524kB slab_unreclaimable:7240kB kernel_stack:1568kB pagetables:3372kB unstable:0kB bounce:0kB writeback_tmp:0kB pages_scanned:2242 all_unreclaimable? yes
[25088.505077] lowmem_reserve[]: 0 0 825 825
[25088.505089] HighMem free:108kB min:128kB low:236kB high:348kB active_anon:47928kB inactive_anon:47976kB active_file:16kB inactive_file:72kB unevictable:0kB isolated(anon):0kB isolated(file):0kB present:105608kB mlocked:0kB dirty:0kB writeback:0kB mapped:2576kB shmem:16kB slab_reclaimable:0kB slab_unreclaimable:0kB kernel_stack:0kB pagetables:1416kB unstable:0kB bounce:0kB writeback_tmp:0kB pages_scanned:261 all_unreclaimable? yes
[25088.505103] lowmem_reserve[]: 0 0 0 0
[25088.505112] DMA: 1*4kB 1*8kB 1*16kB 0*32kB 1*64kB 0*128kB 1*256kB 1*512kB 1*1024kB 1*2048kB 0*4096kB = 3932kB
[25088.505148] Normal: 721*4kB 0*8kB 0*16kB 0*32kB 0*64kB 0*128kB 0*256kB 0*512kB 0*1024kB 0*2048kB 1*4096kB = 6980kB
[25088.505174] HighMem: 1*4kB 1*8kB 0*16kB 3*32kB 0*64kB 0*128kB 0*256kB 0*512kB 0*1024kB 0*2048kB 0*4096kB = 108kB
[25088.505201] 2270 total pagecache pages
[25088.505204] 1716 pages in swap cache
[25088.505208] Swap cache stats: add 691544, delete 689828, find 79702/92115
[25088.505218] Free swap = 0kB
[25088.505221] Total swap = 2028540kB
[25088.513422] 253920 pages RAM
[25088.513434] 26610 pages HighMem
[25088.513437] 5340 pages reserved
[25088.513440] 357 pages shared
[25088.513442] 244960 pages non-shared
[25088.513446] [ pid ] uid tgid total_vm rss cpu oom_adj oom_score_adj name
[25088.513469] [ 337] 0 337 737 1 0 -17 -1000 udevd
[25088.513476] [ 1688] 0 1688 595 11 0 0 0 rpcbind
[25088.513481] [ 1719] 110 1719 663 1 0 0 0 rpc.statd
[25088.513495] [ 1733] 0 1733 645 0 0 0 0 rpc.idmapd
[25088.513502] [ 2092] 0 2092 6986 0 0 0 0 rsyslogd
[25088.513507] [ 2129] 0 2129 503 0 0 0 0 acpid
[25088.513512] [ 2184] 0 2184 539 0 0 0 0 atd
[25088.513525] [ 2242] 0 2242 426 0 0 0 0 acpi_fakekeyd
[25088.513531] [ 2244] 0 2244 960 14 0 0 0 cron
[25088.513536] [ 2312] 102 2312 825 1 0 0 0 dbus-daemon
[25088.513541] [ 2408] 106 2408 789 0 0 0 0 avahi-daemon
[25088.513554] [ 2409] 106 2409 789 0 0 0 0 avahi-daemon
[25088.513560] [ 2434] 0 2434 1122 0 0 0 0 bluetoothd
[25088.513566] [ 2593] 0 2593 1910 1 0 0 0 cupsd
[25088.513571] [ 2756] 105 2756 1856 1 0 0 0 exim4
[25088.513584] [ 2792] 0 2792 7870 0 0 0 0 lightdm
[25088.513589] [ 2817] 0 2817 4682 40 0 0 0 NetworkManager
[25088.513594] [ 2838] 0 2838 20383 466 0 0 0 Xorg
[25088.513599] [ 2842] 0 2842 5976 0 0 0 0 polkitd
[25088.513611] [ 2847] 0 2847 1723 0 0 0 0 modem-manager
[25088.513618] [ 2861] 0 2861 1617 0 0 -17 -1000 sshd
[25088.513623] [ 2885] 0 2885 946 1 0 0 0 getty
[25088.513628] [ 2886] 0 2886 946 1 0 0 0 getty
[25088.513640] [ 2887] 0 2887 946 1 0 0 0 getty
[25088.513647] [ 2888] 0 2888 946 1 0 0 0 getty
[25088.513652] [ 2889] 0 2889 946 1 0 0 0 getty
[25088.513657] [ 2890] 0 2890 946 1 0 0 0 getty
[25088.513662] [ 2904] 0 2904 6747 0 0 0 0 console-kit-dae
[25088.513675] [ 2980] 0 2980 6595 0 0 0 0 upowerd
[25088.513680] [ 3111] 0 3111 3912 0 0 0 0 lightdm
[25088.513686] [ 3133] 1000 3133 484 0 0 0 0 sh
[25088.513691] [ 3149] 1000 3149 968 7 0 0 0 ssh-agent
[25088.513703] [ 3152] 1000 3152 880 0 0 0 0 dbus-launch
[25088.513709] [ 3153] 1000 3153 862 1 0 0 0 dbus-daemon
[25088.513714] [ 3161] 1000 3161 1586 1 0 0 0 xfconfd
[25088.513719] [ 3167] 1000 3167 1662 29 0 0 0 xscreensaver
[25088.513732] [ 3169] 1000 3169 7245 70 0 0 0 xfce4-session
[25088.513739] [ 3174] 1000 3174 5598 128 0 0 0 xfwm4
[25088.513744] [ 3176] 1000 3176 4834 0 0 0 0 xfsettingsd
[25088.513749] [ 3177] 1000 3177 33568 29 0 0 0 Thunar
[25088.513761] [ 3179] 1000 3179 2228 0 0 0 0 gvfsd
[25088.513767] [ 3182] 1000 3182 29157 353 0 0 0 xfce4-panel
[25088.513773] [ 3183] 1000 3183 29601 227 0 0 0 xfdesktop
[25088.513778] [ 3186] 1000 3186 5064 0 0 0 0 panel-6-systray
[25088.513790] [ 3187] 1000 3187 7022 0 0 0 0 xfce4-power-man
[25088.513796] [ 3188] 1000 3188 5391 35 0 0 0 xfce4-settings-
[25088.513801] [ 3196] 1000 3196 4914 0 0 0 0 xfce4-power-man
[25088.513807] [ 3199] 1000 3199 9630 0 0 0 0 system-config-p
[25088.513819] [ 3200] 1000 3200 10666 0 0 0 0 xfce4-volumed
[25088.513826] [ 3202] 1000 3202 50680 0 0 0 0 nm-applet
[25088.513831] [ 3204] 1000 3204 28655 50 0 0 0 update-notifier
[25088.513836] [ 3211] 1000 3211 8598 1 0 0 0 gvfs-gdu-volume
[25088.513842] [ 3213] 1000 3213 2077 22 0 0 0 gconfd-2
[25088.513855] [ 3215] 1000 3215 6776 0 0 0 0 polkit-gnome-au
[25088.513861] [ 3218] 0 3218 5818 0 0 0 0 udisks-daemon
[25088.513866] [ 3221] 0 3221 1589 12 0 0 0 udisks-daemon
[25088.513871] [ 3224] 1000 3224 4777 1 0 0 0 gvfs-afc-volume
[25088.513885] [ 3233] 1000 3233 2167 0 0 0 0 gvfs-gphoto2-vo
[25088.513890] [ 3238] 1000 3238 2359 1 0 0 0 gvfsd-trash
[25088.513896] [ 4298] 1000 4298 6459 0 0 0 0 gvfsd-network
[25088.513908] [ 4307] 1000 4307 2239 0 0 0 0 gvfsd-dnssd
[25088.513916] [ 4553] 1000 4553 1116 1 0 0 0 linuxcnc
[25088.513921] [ 4592] 1000 4592 858 1 0 0 0 linuxcncsvr
[25088.513927] [ 4610] 0 4610 736 0 0 -17 -1000 udevd
[25088.513939] [ 4611] 0 4611 736 0 0 -17 -1000 udevd
[25088.513946] [ 4613] 1000 4613 935 72 0 0 0 io
[25088.513950] [ 4636] 1000 4636 4304 672 0 0 0 milltask
[25088.513956] [ 4637] 1000 4637 744386 235700 0 0 0 axis
[25088.513961] Out of memory: Kill process 4637 (axis) score 958 or sacrifice child
[25088.513976] Killed process 4637 (axis) total-vm:2977544kB, anon-rss:942588kB, file-rss:212kB
Enlever limiter par le nombre de caractères
[30165.070939] Out of memory: Kill process 5761 (axis) score 958 or sacrifice child
[30165.070946] Killed process 5761 (axis) total-vm:2975804kB, anon-rss:944036kB, file-rss:80kB
[30178.425124] spurious APIC interrupt on CPU#0, should never happen.
[30178.432948] RTAI[math]: unloaded.
[30178.436925] SCHED releases registered named ALIEN PEDV$D
[30178.445857] RTAI[malloc]: unloaded.
[30178.544030] RTAI[sched]: unloaded (forced hard/soft/hard transitions: traps 0, syscalls 0).
[30178.547856] I-pipe: head domain RTAI unregistered.
[30178.547874] RTAI[hal]: unmounted.
S.V.P. un expert
RUN_IN_PLACE=no
LINUXCNC_DIR=
INIVAR=inivar
HALCMD=halcmd
TASK=milltask
HALUI=
DISPLAY=axis
DELAY=
5703
5760
[ 0.073535] dummy:
