problem in my machine lathe TMC250
  • Auteur de la discussion ham86
ham86
good morning
i bought a lathe machine huron TMC 250 about three years ago 2014 , now i
have a probleme with the turret of the lathe cnc stop rotating , when i push the button to change the
tool it doesn't respond it make a sound that it trys to change the tool but it doesn't spinning.
so i hope can any body tells me what's wrong with my machine and what can i do to solve this problem.
waiting for your replay.
osiver
Hello @ham86 below a quick translation for those of our non English speaking members.
Quick translation :
Notre ami a un tour CNC Huron TMC 250 acheté en 2014.
Quand il appuie le bouton de changement d'outil, la tourelle émet un bruit comme si elle allait changer l'outil mais ne tourne pas.
MARECHE
Hello
Breaking between the stepper motor and the gear of the turret?
Have a good day
ham86
first thanks for your replay
i don't think so cause i open the turret and all the part are good. no breaking inside.
osiver
I do not know specifically this machine but I think you could look into these possible causes :
- chips or stuff blocking or hampering the turret movement
- loose linkage between stepping motor and tool holder
- weak power supply in the stepper motor circuitry
- damaged wiring or plug
- defective or disturbed position sensor if any
Did it begin suddenly ?
Have you been able to see if motor is moving at all when pressing button ?
ham86
thank you osiver for the replay
i will look for theme
yes it began suddenly i was drilling holes on a piece of steel ( spool spacer ) and then it just stops spining.
yes the motor is moving normely.
01power
01power
01power
simon74
simon74
pro-ms
David80
taratata
taratata
taratata
Rainer Allemand
Dardar88
Dardar88
Dardar88
