ma CNC va n'importe où
ElectroNath
bonjour, lorsque je lance ma CNC avec un gcode ,elle va n'importe où.je l'ai essayé avec 2 code :
le premier généré avec fusion 360
(1001)
(T1 D=4 CR=0.75 - ZMIN=-1.5 - bullnose end mill)
G90 G94
G17
G21
(When using Fusion for Personal Use, the feedrate of rapid)
(moves is reduced to match the feedrate of cutting moves,)
(which can increase machining time. Unrestricted rapid moves)
(are available with a Fusion Subscription.)
G28 G91 Z0
G90
(Poche 2D3)
T1
S5000 M3
G17 G90 G94
G54
M8
G0 X11.676 Y9.292
Z15
G1 Z5 F1000
Z2.9 F333.3
X11.699 Y9.309 Z2.751
X11.764 Y9.36 Z2.623
X11.854 Y9.444 Z2.535
X11.904 Y9.499 Z2.518
X11.95 Y9.556 Z2.5
X11.952 Y9.559
G3 X10.048 Y10.978 Z2.37 I-0.952 J0.71
X11.952 Y9.559 Z2.239 I0.952 J-0.71
X10.048 Y10.978 Z2.109 I-0.952 J0.71
X11.952 Y9.559 Z1.979 I0.952 J-0.71
X10.048 Y10.978 Z1.849 I-0.952 J0.71
X11.952 Y9.559 Z1.718 I0.952 J-0.71
X10.048 Y10.978 Z1.588 I-0.952 J0.71
X11.952 Y9.559 Z1.458 I0.952 J-0.71
X10.048 Y10.978 Z1.328 I-0.952 J0.71
X11.952 Y9.559 Z1.197 I0.952 J-0.71
X10.048 Y10.978 Z1.067 I-0.952 J0.71
X11.952 Y9.559 Z0.937 I0.952 J-0.71
X10.048 Y10.978 Z0.806 I-0.952 J0.71
X11.952 Y9.559 Z0.676 I0.952 J-0.71
X10.048 Y10.978 Z0.546 I-0.952 J0.71
X11.952 Y9.559 Z0.416 I0.952 J-0.71
X10.048 Y10.978 Z0.285 I-0.952 J0.71
X11.952 Y9.559 Z0.155 I0.952 J-0.71
X10.048 Y10.978 Z0.025 I-0.952 J0.71
X11.952 Y9.559 Z-0.106 I0.952 J-0.71
X10.048 Y10.978 Z-0.236 I-0.952 J0.71
X11.952 Y9.559 Z-0.366 I0.952 J-0.71
X10.048 Y10.978 Z-0.496 I-0.952 J0.71
X11.952 Y9.559 Z-0.627 I0.952 J-0.71
X10.048 Y10.978 Z-0.757 I-0.952 J0.71
X11.952 Y9.559 Z-0.887 I0.952 J-0.71
X10.048 Y10.978 Z-1.017 I-0.952 J0.71
X11.952 Y9.559 Z-1.148 I0.952 J-0.71
X10.048 Y10.978 Z-1.278 I-0.952 J0.71
X11.952 Y9.559 Z-1.408 I0.952 J-0.71
X11 Y11.456 Z-1.5 I-0.952 J0.71
G1 X10.863 F1000
G3 X10.544 Y11.137 I0 J-0.319
G1 Y10.863
G3 X10.863 Y10.544 I0.319 J0
G1 X11.137
G3 X11.456 Y10.863 I0 J0.319
G1 Y11.137
G3 X11.137 Y11.456 I-0.319 J0
G1 X11
G2 X10.369 Y11.905 I0 J0.668
G3 X9.607 Y11.776 I-0.371 J-0.129
G1 Y9.926
G3 X9.926 Y9.607 I0.319 J0
G1 X12.074
G3 X12.393 Y9.926 I0 J0.319
G1 Y12.074
G3 X12.074 Y12.393 I-0.319 J0
G1 X9.926
G3 X9.607 Y12.074 I0 J-0.319
G1 Y11.776
G2 X8.59 Y10.25 I-1.653 J0
G3 X7.573 Y8.725 I0.636 J-1.525
G1 Y7.892
G3 X7.892 Y7.573 I0.319 J0
G1 X14.108
G3 X14.427 Y7.892 I0 J0.319
G1 Y14.108
G3 X14.108 Y14.427 I-0.319 J0
G1 X7.892
G3 X7.573 Y14.108 I0 J-0.319
G1 Y8.725
G2 X6.66 Y7.237 I-1.669 J0
G3 X7.066 Y5.539 I0.407 J-0.8
G1 X16.142
G3 X16.461 Y5.858 I0 J0.319
G1 Y16.142
G3 X16.142 Y16.461 I-0.319 J0
G1 X5.858
G3 X5.539 Y16.142 I0 J-0.319
G1 Y5.858
G3 X5.858 Y5.539 I0.319 J0
G1 X7.066
G2 X8.595 Y4.519 I0 J-1.657
G3 X10.124 Y3.5 I1.529 J0.637
G1 X18.5
Y18.5
X3.5
Y3.5
X10.124
X10.2 Y3.507 Z-1.485
X10.274 Y3.529 Z-1.47
X10.332 Y3.558 Z-1.426
X10.384 Y3.596 Z-1.383
X10.416 Y3.626 Z-1.318
X10.444 Y3.659 Z-1.253
X10.461 Y3.684 Z-1.1
Z15
M9
G28 G91 Z0
G90
G28 G91 X0 Y0
G90
M5
M30
le résultat est que la CNC monte en Z jusqu'à se que je l'arrête manuellement (reset)
le second a été recopié sur YouTube, c'est celui présent dans la vidéo.
g21
g90
g17 g40 g49
g0 x 5 y 5
f 400
g1 x 5 y 10
g1 x 10 y 10
g1 x10 y5
g1 x 5 y 5
m2
et là c'est le x et y qui se déplace en positif.
Chose étrange est que l'entièreté du gcode, a l'exception du M2 est remplit instantanément(voir vidéo).
la CNC est une imprimante 3d geeetech i3 reconvertie donc elle utilise un arduino et un cnc shield V3 avec 4 DRV8825. Le firmware est GRBL 1.1
les steps par mm ont été réglé approximativement avec une règle en attente de la fraise et du xyz probe. pour les contrôleur ils sont réglés en 0.51v pour la formule Imax=Vref * 2 donc Vref = Imax/2 soit 0.5=1/2.
Je débute dans la CNC ,mais je suis plutôt bon connaisseur en Arduino et impression 3d.
merci de votre aide.
EDIT: De plus en dehors des déplacement avec les flèches ,la machine fait un bruit monstrueux et les moteurs sifflent.
ElectroNath
bonjour j'ai trouvé le problème mais pas la solution, les valeur machine sont -200 sur tout les axe après le homing. es que vous savez comment les remettre a 0?
speedjf37
Un peu de lecture pour comprendre Grbl:
Cordialement JF
ElectroNath
Bonjour merci pour ce peu de lecture le fait d'entrée G92 X0 Y 0 Z0 m'a permis de faire le g-code présent dans ma vidéo(le second) mais je suis toujours au même problème avec le g-code généré par fusion 360. Je pensais que cela pouvait venir du fait qu'il puisse essayer d'aller en position positive alors que les valeurs les plus hautes sont 0. Est ce possible ?
Je n'avais pas remarqué mais la vidéo est retourné, ce que vous voyez à gauche est en fait a droite.
speedjf37
Quel est le logiciel de pilotage utilisé ?
Est ce le jog sur les 3 axes fonctionne ?
Quelles sont les limites atteintes ?
Quelles sont les limites théoriques des axes ?
ElectroNath
Le logiciel de pilotage est grbl control. Le jogging fonctionne normalement.les limite matériel sont de 200 et dans le grbl 190.
Le code s'arrête a f200. Juste avant il y a G28 G91 Z0 G90. Il parle de position de sécurité pour le spindle mais je ne sais pas ce que c'est
speedjf37
Le G28 est une catastrophe sur beaucoup de CNC.
Nous l'avons éliminé depuis plus de soucis
ElectroNath
Je teste sans
Merci énormément c'était tout con mais merci ça fonctionne.
N'y a t'il pas une fonction sur fusion pour arrêter de mettre le g28
J'ai toujours le problème, mais a la fin maintenant. Il y avait un g28 que j'ai enlevé mais il le fait toujours.
M4vrick
gaston48
Albinos38150
P.Taramesh
VARIAXIS01
01power
01power
01power
taratata
taratata
taratata
modjo756
bistouc
bistouc
