abagrizzli
Hi, guys, I would appreciate help if anyone can recognize the possible reason.
Our lathe started to make an unsual noise.
We have found this washer and screw on the bottom of the primary gearbox, I believe it does some function of retracting low gear sprocket - makes noises only when in low and high not fully disengaged ( you can see the wear marks where the sprocket comes in contact).
Any ideas where does the screw belong and what I have to disassemble to get inside?
Thank you for any help.
