axe z dont work
  • Auteur de la discussion skander ben ahmed
skander ben ahmed
hello everyone
i have a big problem
i'm preparing a cnc machine for my final project
i'm using inkscapr to generate gcode files and i use universal g code sender
the problem is when i finish the file in inkscape and open it in universal gcode sender it , only axe z dont work
jpbbricole
Hi
Which extension do you use in Ikkscape?
Can you put your G-code file as an attachment?
cordially
jpbbricole
skander ben ahmed
i use migrbl z-axes serv controller
jpbbricole
Hi!
Have you installed the special version of GRBL with servo management, if yes, which version?
Is the servo connected to the Arduino pin D11?
Next, it would be good if you put the Inkscape drawing and the G-code file generated by the migrbl extension as an attachment .
cordially
jpbbricole
furynick
Dudulle
Dudulle
Greg de Nîmes
Albinos38150
01power
01power
01power
pro-ms
David80
taratata
taratata
taratata
aschamba
aschamba
aschamba
taratata
taratata
taratata
